Old 06-29-2023, 12:23 PM   #1
1981_c10
1981_c10's Avatar
LS Swap Pedal Bracket
Did anyone on here order an pedal bracket from Hart_Rod that is for a 67-72 c10 and modify for 73-87?
I got one from him and looking to try to use for my ls swap but am not a fabricator and looking for some help on how i can make it work.
Builds:
1962 C10 Recreating Dad's High School Truck
1981 C10
1981_c10 is offline   Reply With Quote
Old 07-03-2023, 01:27 PM   #2
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: LS Swap Pedal Bracket
I did not use his bracket for my swap, but I know he is a stand up guy. I would say that you could look through the thread for the bracket and also give him a PM on here. I don't think it is a very difficult install though...
good luck & keep us posted on it.
rodstored-72 is offline   Reply With Quote
Old 07-14-2023, 07:01 PM   #3
1981_c10
1981_c10's Avatar
Any help??
Builds:
1981 C10
Old 07-16-2023, 10:57 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what pedal are you using?
do you have throttle by wire or cable?
if its cable, you can simply use the OEM LS truck cable and it fits like a glove
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-18-2023, 10:22 AM   #5
MalibuSSwagon
Holley sells a bracket. Kinda pricey for a chunk of flat plate steel.
I'll probably design my own once I get to that stage of my Gen4 swap.
MalibuSSwagon is offline   Reply With Quote
Old 07-18-2023, 09:17 PM   #6
cdub2010
Im not sure why you need to buy a bracket, a flat piece of steel works fine. My k30 setup is attached. I haven't driven it yet but it feels solid and the pedal has full movement but needs to be moved a bit to the right for better a fit. I may not keep this as im not sure it will work with my current 8.1 vortec setup.
My first swap in a 77 k25 I used a gmt400 diesel pedal, it bolted right in, no bracket needed. That pedal is to sensitive for my liking, which i why im thinking about a dbc setup.
cdub2010 is offline   Reply With Quote
Old 07-19-2023, 09:29 AM   #7
MalibuSSwagon
I'd prefer to stay with DBC, but I'm swapping to a GEN4 LS2 from my Gen3 5.3, so I have to use DBW. I can easily design a bracket and cut it on my plasma table, it doesn't have to be fancy.
What pedal is that? The monte carlo one?
