Old 10-06-2011, 07:53 PM   #1
burlapen
burlapen's Avatar
Motor mounts sold out....now what??
After a moderate amount of research I decided on the ECE mounts for my 5.3 swap. I went by to pick them up today and they informed me a portion of the mount is made in house and a portion is sourced from GM. GM has discontinued making there half!!!! So, I am wondering what my next best option is as far as mounts. I would like to retain my AC compressor in the stock location if possible. All of this is on my 63 C10 by the way. What mounts are everyone else having luck with? Just a heads up, Im not a great fabricator or welder so something bolt in would be preferred. Thanks!!
63 Chevy C-10
My build thread
burlapen is offline   Reply With Quote
Old 10-06-2011, 09:07 PM   #2
ZR2RICK
ZR2RICK's Avatar
Re: Motor mounts sold out....now what??
iv'e got a new pair of ece prothane mounts i'm not going to use maybe they would work for you. they are 2-3/8" between the ears,2-3/4" tall.
Learn to deal with reality, or reality will deal with you.
ZR2RICK is offline   Reply With Quote
Old 10-07-2011, 06:20 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't run a/c so I'm not sure if this will work;
I just used the standard cheap swap plates, stock mounts and stock 6 cylinder perches. Moved the perches to the front hole, and welded the mounts in place to be secure. You don't HAVE to weld them, some grade 8 hardware would work fine as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-07-2011, 10:23 PM   #4
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
If he can't use them I might be interested in them...
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 10-07-2011, 10:36 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I thought the "GM half" was just the frame stands from a 73-87 truck?
I would veriify that from ECE and just use a used set of frame stands.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 10-08-2011, 10:21 AM   #6
Shon
I have been looking at dirtydingo for motor mounts, they offer adjustable ones that look really cool.
I used stock motor mounts with transdapt plates on the motor....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 10-08-2011, 01:51 PM   #7
burlapen
burlapen's Avatar
Thanks for the replies everyone! Rick, are those LS style mounts? It looks like from the picture they have the regular small block on one side but I'm confused where the forked side goes. Lolife, I believe you are correct, I may see if I can stir up some frame brackets and ask if they will sell me the top "half" only. Shon, are you happy with the trans dapt mounts and where your engine sits fore and aft?
63 Chevy C-10
My build thread
Old 10-08-2011, 01:58 PM   #8
Shon
heck yeah!
I used the stock style mounts (poly replacement) thinking it would be a 'cheaper' route and wanted to show people that you do not have to get the 'high dollar' stuff. but in the end its within a few bucks, slightly cheaper and works but do like the ECE set up. Just wanted to be different.
Old 10-08-2011, 02:58 PM   #9
ZR2RICK
ZR2RICK's Avatar
they are Ls mounts, I have 1969 Camaro frame stands, the forked part mounts to the frame stands of your choosing, lots of guys make their own.
Old 10-08-2011, 08:53 PM   #10
short-t
short-t's Avatar
Sorry, those are not LS engine mounts. LS engine mounts use four bolts to mount to the block, those are sbc mounts!
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
Old 10-08-2011, 09:06 PM   #11
ZR2RICK
ZR2RICK's Avatar
they are LS mounts, I had them mounted to plates that adapt to the LM7 I have. I have a set of small block Chevy mounts i can show you if you like.
Old 10-08-2011, 09:18 PM   #12
short-t
short-t's Avatar
Need I say more?
Old 10-29-2011, 05:35 PM   #13
Vandals909
So this is a bummer, ECE no longer sells there Ls conversion kit?
Thanks!
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Vandals909 is offline   Reply With Quote
Old 10-30-2011, 09:15 AM   #14
exploderjim
exploderjim's Avatar
I just bought the kit from ECE last week. I would call and check.
http://www.earlyclassic.com/catalog....ry=New%20Items
exploderjim is offline   Reply With Quote
