Tube Frame 53
Got this truck in the shop for a full tube frame, LS swap, air ride, fuel cell and some cosmetic sheetmetal repair. The customer gave me full freedom to do what I wanted, only thing he needed was a trailer hitch.
Ive build dozens of frames out of square tube but never one out of round, and me and the old man have been cranking out rock crawler and rzr cages like crazy lately so I decided to build this one out of round and take advantage of all that space under these trucks. I really like how tootsie was built so I first laid everything out in bend tec ![]() Then started bending and notching ![]() sleeved my joints ![]() And got my front clip installed. This is a modified mustang II frontend I designed and have used on a few of my builds. It uses the same spindles, rotors and calipers, rack & pinion as a mII setup but I played with the geometry to get up to 10'' of travel with only 3* camber change and just works better laying out with big wheels. It uses offset tab inserts in the upper arm mounts to get its adjustment, its similar to the new GM and dodge mounts, only with the inserts the arms can never slip out of adjustment. ![]() Cab mounts ![]() ![]() ![]() 4.8 LS going in. It fit like a glove. ![]() 4 link tabs ![]() Center section ![]() That's what 2 days have got me. Ill be ordering the frontend parts and all the air management on Monday. |
Re: Tube Frame 53
Can't wait to see more of this build. You work fast if you did that all in two days.
Re: Tube Frame 53
wow looking forward to this build! should be a quick one if you got that much done in 2 days!
Re: Tube Frame 53
Guilty by Design, Great looking chassis. I love the design of it. I started to build one for a buddy years ago. It was made out of 1 5/8 tube. It never got finished because he lost his job and then started a business. But at least it was a roller. I can not wait to see more.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
Re: Tube Frame 53
i like what i see already
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() Join Date: Mar 2011
Re: Tube Frame 53
Wow, I'm amazed at the talent on this site...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Re: Tube Frame 53
Thanks for the words. I ordered all the air management, balljoints and reamer bit, and front brakes today. Tomorrow the customer is bringing the cab over so I can mount it with the running boards and get my final placement of the motor. Speaking of the motor we realized today that the drivers side head is cracked (junkyard motor) so if he can get the yard to replace it he may pay up and get a 5.3. Our biggest hang up right now is the wheels, he wants 15'' steel rally wheels and finding a matching set locally is difficult. I think were looking for 2wd front wheels and 4wd rears (the 4wd wheels being wider) so I gotta get those located pretty soon.
#8 | |
Re: Tube Frame 53
Re: Tube Frame 53
Got a few hours his week to work on it. We located the wheels and tires were gonna run.
![]() Most of the parts showed up late today so I couldn't do a lot. Got all the air management, balljoints, and rack & pinion. ![]() Fixed some rust while I waited on parts ![]() ![]() ![]() ![]() And got the motor mounted ![]() |
Re: Tube Frame 53
Nice progress. Did you put in a new cab mount? Did you coat the area in between the inner and outer cowl area with anything before you welded in the new inner cowl? One thing that irritated me with the new floor pan is that my original battery cover doesn't fit in the new opening. The radius in the corners is larger than the cover.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
Re: Tube Frame 53
I got some weld thru primer on the underside, we will have it rhino lined before it hits the road. I didn't replace the cab mount piece since it was ugly, but still sturdy. These panels fit great tho. He said he got them through LMC but I cant recall the brand name.
Re: Tube Frame 53
I got mine through LMC too. I think they said Tri Plus on them.
Re: Tube Frame 53
Almost to afraid to ask, but what would a chassis cost like you have built, just the chassis no running gear? I have a 54 gmc I am looking for a chassis for and this one would fit the bill.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
![]() Join Date: Mar 2010
Re: Tube Frame 53
Nice work.... Subscribed.
#15 |
Re: Tube Frame 53
without a rearend too? I would imagine i could have the rails, crossmember, and 4 link build for around $3500-4000.
#16 |
Re: Tube Frame 53
Had some time to play with it between jobs. Got the cab, frontend, and running boards mounted, 4 link done, 23gal alum fuel cell fabbed and mounted, and im getting all the air management placed under the cab as well.
#17 |
![]() Join Date: Mar 2007
Re: Tube Frame 53
Your killin it. it looks really nice.
Keep it up. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#18 |
Re: Tube Frame 53
This truck build is slick
#19 |
Re: Tube Frame 53
Sweet...Jim
#20 |
Re: Tube Frame 53
Finally got some time to work on it lately. Its a full roller for now and the owner will be bringing it back over the fall and winter to finish up some details. We ended up getting another 4.8 LS1 for it and sending the harness and computer off to get tweaked on. After throwing on some shorty headers and clearing out some sheetmetal she fits in there snug.
![]() Just some shots from underneath. The best part of him bringing me a pile of 65 year old parts is its leaving with a modern frame and drivetrain... but still looking like a 65 year old pile of parts. ![]() ![]() ![]() Ill get some full pics of it outside tomorrow. |
#21 |
Re: Tube Frame 53
Looking good...Jim
#22 |
Re: Tube Frame 53
#23 |
Re: Tube Frame 53
Now that's on the ground!!!...Jim
#24 |
Re: Tube Frame 53
Looks really good
#25 |
Re: Tube Frame 53
X2
