Chevy Enthusiast
np205 short vs long 32 spline input
Does anyone know where I can find a long version? I have a short version but I'm getting a custom adapter made for the nv4500 and figure 8 np205 and I need the other shaft. The short 32 seems to be more desirable of the two but I'm still having trouble finding the long 32 spline input. Thanks in advance!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
Re: np205 short vs long 32 spline input
off road design.
they will get about anything you need for a 205. anyone doing a nv4500 swap that is not using the spacer would have one too i would think. |
Chevy Enthusiast
I'll look again and see what they have available. Thanks
no problem. you may call. they are very helpful and may not list it as most people are going the other direction.
That is not a reproduced part so if they have it, it will be a used one. Hit or miss on the long gears. I'll buy your short gear if it comes to it.
The long gears come up on pirate4x4 from time to time. why the custom adapter? Have you seen this? You can use your tcase with the short gear and this plate All with the stock 4x4 trams adapter. http://www.northwestfab.com/GM-NP205...pter_p_18.html Last edited by obijuan; 03-31-2015 at 02:36 PM. |
