Old 04-22-2004, 11:14 PM   #1
chicogixr
what transfer case do i have?
i have a 79 K10 and i want to know how to tell what transfer case i have. i dont want anyone to tell me what i should have or what i might have. tell me how to prove it. what do i need to look for? does anyone have pictures so i can see? thanks.
Semper Fi
seafoam green 79 K10 stepside with a 6" lift, 33" baja claws, billet interior, autometer gauges, 350/t350
chicogixr is offline   Reply With Quote
Old 04-22-2004, 11:29 PM   #2
Destructo
Should be a NP203, but the way to find out is to look at the metal plate which is riveted on the back side of the case, its a round metal tag with a rivet in the middle and it has little red border around it, the model will be stamped in into that plate, should say New Process and then 3 numbers, I suspect the 3 numbers will be 203.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 04-23-2004, 12:29 AM   #3
1969 GMC
1969 GMC's Avatar
that tag may not be there, but an easy way to check is to look at your transfer case shift knob (if that is there, lol). if it says something like "Hi, Hi Lock, Lo, Lo Lock" then its a NP203 (fulltime 4x4). if it says "2 Hi 4 Hi N 4 Lo" then you have the NP205 part-time case. of the 2, the NP205 is better, but the NP203 is more commong and it isn't that bad.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 04-23-2004, 08:46 AM   #4
ryanroo
ryanroo's Avatar
if its all factory, then with a 4 speed its a 205 with an auto should be 203. look between the rear output and the bottom aluminum coverplate(round with 6 bolts holding it on) if there is a little circle of metal about 2.5 inches in diam. held on by three bolts, its a 205, if not a 203
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
