Old 05-05-2004, 05:03 PM   #1
BigRed
Audio Question - Amplifier Hookup
For any of you car audio guys, I need a little help. It's been like 15 years since I've wired an amp in so I have some questions.
I have an amp that I'm wanting to run both channels into one subwoofer. My memory tells me that I can run one channel's (+) to the woofer's (+) and the other channel's (-) to the woofer's (-). Is that correct? Also, I have a setting on the amp for 2 ohm and 4 ohm. Would I want to run 2 ohm with this bridged-mono setup?
Just to let you know what I'm doing. I recently bought some 2way Audiobahn 3.5's for the dash and 2 4x10 components (with crossovers) for the rear of my suburban. I plan on running those off of a new 50w per channel head unit and then I'm going to run a sub (not sure which yet) off of a 400W kenwood amp. I've already hooked up the mids and highs to the old crappy head unit I have and it already makes a huge difference. I can't wait until I have everything hooked up.
I'm currently going through a divorce and that's why I haven't been on in awhile. And that's also why I'm now starting to do some more stuff to my truck because I have more free time now.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 05-05-2004, 05:35 PM   #2
Low87
been here longer than Liz
Low87's Avatar
Nice to see you back around! Sorry to hear about the family, you and Brandon running off together?
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 05-05-2004, 06:43 PM   #3
BeerMonkeY
sold
BeerMonkeY's Avatar
how many subs and what is the ohm rating of the sub(s), it will be on the back of the sub. if its a single sub then just hook it up bridged, it shound say what terminals on the amp are the ones to make it bridged. also is it a single voice coil (1 set of terminals) or a dual voice coil (2 sets of terminals)?
BeerMonkeY is offline   Reply With Quote
Old 05-05-2004, 09:28 PM   #4
corn
make sure that the amp can be wired mono. if its a stereo only amp you will fry it wiring it mono. also make sure that you have the subs wired to the ohm load you want to run. *see pic*...corn
corn is offline   Reply With Quote
Old 05-05-2004, 09:39 PM   #5
phantom dually
Project92 SWB stepside
phantom dually's Avatar
almost any amp can be wired mono. What you have to watch out for is make sure that you dont run say a KENWOOD amp past 4 ohm mono. Most amp are only rated to run 4 ohm mono unless it is a high dollar amp or a mono block. If you had 2 subs that where 4 ohm each you have to run them with the kenwood at either 8ohm mono (series wiring) or in stereo. Essentially 8 ohm would be the same as 4 ohm stereo to 2 subs. Mono wiring would be best even though it is 8 ohm because the subs would hit at the same time. To run the kenwood with 2 subs you will need to 8 ohm subs wired in parallel or 1) 4 ohm sub.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 05-05-2004, 09:54 PM   #6
C-10volvo
C-10volvo's Avatar
agreed.
give us some feed back on how thoes subs sound!!
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-06-2004, 12:06 AM   #7
swervin ervin
swervin ervin's Avatar
Damn, what's up with all these divorces?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-06-2004, 08:22 AM   #8
BigRed
Greg, if I was to run off with anyone, she'd have a lot more hair and a lot smaller waist than Brandon (no offense buddy). Although, from what I hear, B is getting alot closer to that smaller waist!
I don't know Mike. I definitely never thought it would going through this. I just married somebody that hid alot from me and has never been honest. When you can't believe a word your own spouse says, it's really hard to trust and stick by them. Unfortunately, I have two young kids and that is the hardest part. However, I think they will see more love with us apart then they ever did with us together.
To the rest of you, thanks for the help. The amp I have is bridgeable and can be switched between 2 and 4 ohms. From what y'all have said, it should be fairly simple. Like I said, I've done this stuff before. I haven't bought subwoofers yet. My plan (because I'm on a budget), is to just buy one 12" and a ported enclosure. I'm not going for tremendous bass, however I do want some good sound. With only a 400W Kenwood amp, I probably will need to stick with the single voice coil sub because that's about all it could push. I'm currently looking at an Audiobahn and an MTX. I figured since all my other speakers are Audiobahn that maybe I should just finish it out with one. We'll see. I'll let you y'all know how it sounds.
Scott Shelbourne
Old 05-06-2004, 10:00 AM   #9
C-10volvo
C-10volvo's Avatar
if you have'nt gotten the subs yet, check out this site. www.discountsjungle.com my friends and i have orderd a lot from them and they are top notch people
Ken Morgan
