Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 03-22-2004, 09:57 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
WTB- NOS 73-80 trim
I'm looking for a complete set of NOS GM side molding for a 73-80 short fleet. I will consider pieces, but it must be in new condition....
PM or Email me at abcmusic@sbcglobal.net
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-22-2004, 10:42 PM   #2
Russell
Professional Grade
Russell's Avatar
You gettin rid of the gold trim?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-22-2004, 10:46 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
No I'm keeping it. There are a couple of pieces that need replacing due to minor damage. I tried the LMC stuff but it doesn't look like I want, so I'm trying to find a complete set of NOS GM trim to replace it all at once...
Old 03-23-2004, 01:32 AM   #4
bigblock73
yeller
bigblock73's Avatar
PM'd ya Ken...hurry up and check it.
bigblock73 is offline   Reply With Quote
Old 03-23-2004, 01:36 AM   #5
SCOTI
SCOTI's Avatar
If Ken doesn't buy it all.....I need some too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-25-2004, 12:51 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
anyone?
Old 04-01-2004, 11:31 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
ttt
Articles-
"Refining Sierra"
Old 04-04-2004, 09:42 AM   #8
Nvbowtie
Nvbowtie's Avatar
Try www.gmpartsdirect.com
you'll need the part numbers
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 04-04-2004, 07:32 PM   #9
SCOTI
SCOTI's Avatar
Okay.... where can you find the parts #'s?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-05-2004, 08:01 PM   #10
SCOTI
SCOTI's Avatar
Keeping this TTT
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-06-2004, 05:16 AM   #11
Nvbowtie
Nvbowtie's Avatar
Parts illustration book, or go to dealer they can pull up part numbers off thier computer
Here is example of research for my 1980
345123 Rear cab Mld Center
345124 Rear cab Mld corner RH
345125 Rear cab Mld corner LH
347705 Dash emblem
364377 Door Handle trim - GM uses this number for L/R
364379 Door panel trim ring LH
364380 Door panel trim ring RH
461616 Dash plaque
466759 Aluminum panel -LH
466760 Aluminum panel -RH
Old 04-06-2004, 02:55 PM   #12
SCOTI
SCOTI's Avatar
I was hoping for something from possibly the internet. I hate to tie up the parts guys 'puter just to look. If I already had PN's walking in the door, they will do a search for what you seek.
No PN's & since everything is discontinued, that's as far as they go (w/o much effort to actually search).
Thanks for the tips though.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-06-2004, 03:39 PM   #13
Jonboy
Slots go on anything!
Fender
Rt mldg. upper-6260840
Lt. mldg upper -6260839
Rt. mldg. front-374295 Lt same part #
Rt. lower mldg-6260842
Lt. lower mldg-6260841
"Cheyenne 10" nameplate 14016636
Door
Rt upper mldg; yellow-463608
Lt. upper mldg yellow -463607
Rt. upper black-475544
Lt. upper black-475543
Rt. lower yellow-463612
Lt. lower yellow-463611
rt. lower black-475560
Lt. lower black-475559
Tailgate upper and lower-475535
I got these from the estimating system I use at work. I need to know the wheelbase measurements for long and short to sort the stuff from the bed moldings I found. That and I can't type, so those took forever. Not all of the moldings were showing both black and yellow, I put up what I could find. I also don't know which ones might be discontinued.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-06-2004, 08:58 PM   #14
SCOTI
SCOTI's Avatar
Jonboy.... you 'da man.
The wheelbase is 117.5". I'm suprised they list them as black or yellow. I assumed they would be one color or the other & more than likely whatever color was available last.... yellow.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-06-2004, 09:07 PM   #15
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Most of these pieces are not discontinued, but the ones that are available are available only in black.
Ken - if you still need help with this, pm me. I just bought an NOS set at the swap meet in Portland this weekend. I have all the pieces and they are all really easy to get to if you want me to look at some numbers.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 04-06-2004, 09:29 PM   #16
SCOTI
SCOTI's Avatar
Good to know. The more I thought about it, black would be the more common color since the yellow was 77 only right?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-06-2004, 10:15 PM   #17
bigblock73
yeller
bigblock73's Avatar
correct.
Old 04-06-2004, 11:14 PM   #18
Jonboy
117.5" is shortbed, correct? I will add the rest of them tomorrow.
Old 04-07-2004, 12:14 AM   #19
SCOTI
SCOTI's Avatar
Excellent. I can't thank you enough..... or can I? Your not too far away that I couldn't supply you w/a frothy beverage or 2 .
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-07-2004, 10:46 AM   #20
Jonboy
Bed Moldings-
Rt. upper w/o 117.5 wb-black-475550
Lt. " -475549
Rt. upper w/o 117.5 wb-yellow-463618
Lt. " -463617
Rt. Upper w/ 117.5 wb black-475548
Lt. " -475547
Rt. Upper w/117.5 wb yellow-463656
Lt " -463655
Rt. molding lower front w/o 117.5 wb black-475564
Lt. " -475563
Rt. molding lower front w/o 117.5 wb yellow-463624
Lt. " -463623
Rt. lower molding rear w/o 117.5 wb-black-475566
Lt. " -475565
Rt. lower molding rear w/o 117.5 wb yellow-463614
Lt. " -463613
Rt. front lower w/117.5-black-475562
Lt. " -475561
Rt. front lower w/ 117.5 yellow-463352
Lt. " -463351
Rt. rear lower w/117.5 black-475582
Lt. " -475581
Rt. rear lower w/117.5 yellow-463622
Lt. " -463621
Cab moldings behind door-
black-6258145
yellow-463609
I think I got it covered there. Hopefully those are the right numbers, usually the estimating system is right on when it breaks down the options like that.
Old 05-12-2004, 09:59 PM   #21
dswancutt
WTB NOS 78-80 Trim
I don't know if you are still looking, but I found this on eBay.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33654
Doug
dswancutt is offline   Reply With Quote
Old 05-12-2004, 10:30 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Yep, I'm still looking. Thanks for the heads up...
Old 05-12-2004, 10:34 PM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by ElGracho
.... I just bought an NOS set at the swap meet in Portland this weekend. I have all the pieces and they are all really easy to get to if you want me to look at some numbers.
It looks like we have the part numbers covered now. You found a complete NOS set? You lucky dog! If you don't mind me asking, what would I expect to pay if I were to stumble across a set?
Articles-
"Refining Sierra"
Old 05-12-2004, 11:46 PM   #24
ElGracho
ElGracho's Avatar
I paid $200. It was an awesome find since the pieces you CAN get from GM are over $1000 if you're paying list. You can't get the lower rear pieces on the front fenders.
The set I got even included the upper and lower pieces around the grill and the drip rails. I was pretty stoked. Two people I was with at that swap meet had just paid the big bucks to GM. They weren't too happy to see me get that deal...
Old 05-13-2004, 10:59 PM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
I paid $200. It was an awesome find since the pieces you CAN get from GM are over $1000 if you're paying list....
Did you grab it and run? That is stealing ya know. Thats cheap even if it were available at every day low prices.
There is supposed to be a swap meet here this weekend. If I can get my 77 rolling I may try to get by there...
