Old 05-24-2004, 12:07 PM   #1
rickn
rickn's Avatar
Question Clutch
kind of a dumb ques. on this board but her is the only one ive been to but her goes does anyone know how to bleed the clutch on a 84 s10 blazer
http://rick.nicholson.home.insightbb.com
rickn is offline   Reply With Quote
Old 05-24-2004, 05:41 PM   #2
adamls
Gotta Startem Early
adamls's Avatar
I didnt know the 84 Blazer had a hydraulic clutch but if does then I dont know.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 05-24-2004, 09:49 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
The Chilton manual shows a bleeder on the slave cylinder, bleed it like brakes
(pump clutch pedal hold to floor, open bleeder valve,close bleeder valve, repeat)
sneakysnake is offline   Reply With Quote
Old 05-25-2004, 11:33 PM   #4
Johnny Outdoors
SOON TO BE A STEP SIDE
Johnny Outdoors's Avatar
some times when you bleed the slave (just like bleeding brakes) you only get a small amount of fluid out.
once the air is out there doesnt seem to be enough throw on the lever.
try this
have your helper hold the clutch pedal down then hold the throw out lever with a bar so it cannot return when he lets the pedal off. (the bleeder should be closed)
then have him or her press the pedal again and do the same thing
by holding the lever and pressing the pedal again fluid is forced into the slave thus giving you a complete throw on the release lever.
then you can give it one final air bleed and your pedal should be great
just my 2 cents
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY!
4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON
Johnny Outdoors is offline   Reply With Quote
