Old 05-30-2004, 08:15 PM   #1
imdarren
imdarren's Avatar
Axle DeCode Please
Can someone please run these numbers please?
Should be from a 72 C-10
THA W236 1
I would like to know the gear ratio.
Also. Ive heard it before. But can't remember . . . .
You count the teeth on the ring gear an then what?
To determine gear ratio that is.
Thanks!!
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 05-30-2004, 09:17 PM   #2
67sss
67sss's Avatar
rearend
It's a 3:07, according to my book.
67sss is offline   Reply With Quote
Old 05-30-2004, 10:52 PM   #3
ryanroo
ryanroo's Avatar
to determine the ratio you count the teeth on the ring gear and on the pinion gear and then divide the number from the ring gear by the number from the pinion
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-30-2004, 11:43 PM   #4
2low72
is there a way to tell without pulling the cover. i was told once you could count how many time the driveshaft rotates to one full rotation of the tire to figure it out. is that correct??
2014 GMC Yukon XL (Wifey's)
2004 Chevy Silverado Crew Cab Z71
2low72 is offline   Reply With Quote
Old 05-31-2004, 12:04 AM   #5
Hutch
Hutch's Avatar
imdarren
This is what I do to decipher the Rear-end code.
Go to: http://www.americanclassic.com/
Click on the VIN decoder on the left side of display.
Under axle codes check the year 1971.
THA is/was a 3:07
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
