Old 06-26-2004, 10:47 AM   #1
my68c10
rearend conversion
new to the board so i hope this works.
i am wanting to put a rearend from a 81-87 pick-up under my 68 c10. my ? is has anyone used one of the conversion kits, and how did it turn out. i haven't seen this kit on any truck, and until i see one or talk to someone who has used this kit, i'm not buying one. the rearend is actually from a 91 surburban and i am trying to keep the drive train in line.-efi 350-700r4-342posi all under my 68. thanks for any help .
my68c10 is offline   Reply With Quote
Old 06-26-2004, 12:17 PM   #2
walker
walker's Avatar
GM 12 bolt is a fine rear, and is available in many gear ratios. Parts are easy to get, they fit the truck easily, disk brakes are available for them, lockers are easy to get. So, why is it you want to change?
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 06-26-2004, 01:31 PM   #3
SCOTI
SCOTI's Avatar
Do you really need to swap? What is the current ratio of your 68 12-bolt? If it's 3.73's, that's a bunch of work for a very similar ratio. If you consider the $$ for replacement saddles for the rear end, the time it takes to grind off the old leaf spring saddles, welding the new ones on, swapping the rears, bleeding the brakes, re-hooking up all the remaining suspension, it doesn't seem worth it.
I would be willing to bet a lot of guys w/late model trucks & 3.42's would prefer the 3.73's anyway. Food for thought.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-26-2004, 01:36 PM   #4
my68c10
rearend
the main reason for changing is want to run ss crager wheels. i know i could just change the axles but i have the rearend and if the kit works i'd try it. only other positive is that the rear brakes will have the bigger pads. so have you seen the kit on any trucks. thanks for the reply
Old 06-26-2004, 03:29 PM   #5
1972C10
1972C10's Avatar
I put a late model 95 rearend in my 68 SWB it wasnt a big deal at all I took and torched the pads off the 12 bolt and reused them .. then made a panhard bar bracket out of angle iron and welded it to the axle tube Used a 3/4 ton type panhard bar
When i swaped mine it was for a rachet locker 3.73
1972C10 is offline   Reply With Quote
Old 06-26-2004, 04:49 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Get a rearend from a 71-72, and you'll have the bolt pattern you want AND they will swap, bolt for bolt, assuming you have a coil spring rear suspension.
So, you already have 5-lugs on the front?
Member Nr. 2770
Old 06-26-2004, 05:10 PM   #7
my68c10
yes, the frontend came from the 91 surburban and it fit very well. i think i had to egg shape one set of holes in the frame
Old 06-26-2004, 05:20 PM   #8
krue
Designated A-hole!
krue's Avatar
Welcome to the board from South Mississippi! I am with ChevloRay just get a 71-72 rearend unbolt yours and bolt it in it's place. But where there's a will (and a welder) there's a way.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-26-2004, 05:44 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
He has the rear end already!
It would be cheaper for him to swap over to the later rear end. The conversion parts are much cheaper than buying a 71-72 rear end. Besides, you can pretty much guarantee that the 91 Suburban rear end he already has will have less wear and tear on it than a 71-72 rear end. It's 20 years newer.
Early Classics will have everything you'll need, including the special rear end saddles like the earlier trucks use. Just call their tech line and they'll fix you up with what you need.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 06-27-2004, 03:28 AM   #10
1972C10
1972C10's Avatar
If you need more details on how to do it without buying anything Let me know.
I have some before and after type pics of my swap and it came out premo.
