Now the others dig........
![]() Join Date: May 2002
Signs of a bad upper ball joint?????
I get an occasional "pop" on my drivers side when turning, in drive, while holding the brake pedal. usually occurs when I finish backing out of a parking space and put it in gear to go forward...
I have replaced the upper control arm bushings and shafts on both sides...but I have yet to do the lowers. I noticed that the drivers side ball joint was "squished" inwards, like when you squish a deflated ball. so I fattened it up a bit while lubing up the whole front end.....and it returned to that "squished" look again within a few weeks. could my ball joint be freezing up???? it does not seem to hold any grease.....and I do not know where it is going!!!LOL!!! could I have not tightened the ball jount to the knuckle enough...and it may just be moving in and out of the knuckle???? any help would be aprecciated.... also after drving around quite a bit, the brake pedal gets a bit hard....I think it may just be air in my lines.....any other suggs????
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
