Old 07-30-2004, 09:23 PM   #1
76bonanza
76bonanza's Avatar
heater hose question
The PO of my truck put what looks like a shut off valve or something in one of my heater hoses for what pupose would this serve?
Thinking of removing it when I change my heater hose?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-30-2004, 10:35 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
He probably was having problems with the doors in the dash that control the temperature of the air blowing out of the vents. The valve would allow him to shut off the hot water going to the heater core during the summer, keeping it cooler in the cab.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 07-30-2004, 10:37 PM   #3
76sierraclassic
It's probably a manual shut off valve for the heater core. Our old trucks didn't come with a valve of any kind to keep the heater core from circulating water all the time, and since you don't typically need your heater in the summer, you can install a manual valve to shut off the water flow during the hot months. This helps some with A/C by not having to overcome the "hot box" under the dash. I've even seen folks who have taken the hose that goes into the heater core and loop it right back to the radiator, completely bypassing the heater core.
Mike
76sierraclassic is offline   Reply With Quote
Old 07-30-2004, 10:46 PM   #4
76bonanza
76bonanza's Avatar
That makes since. I hooked my blower fan up to a toggle switch and just shut off the fan in summer. So it will be ok if I remove it when I replace my hoses just dont like the look of it.
1968 c10
lowered 3" 4"
Old 07-31-2004, 02:49 AM   #5
jimfulco
Open the valve & drive it for a while to make sure your feet don't get heated just from the movement of the vehicle.
jimfulco is offline   Reply With Quote
Old 07-31-2004, 07:54 AM   #6
76bonanza
76bonanza's Avatar
I have never touched the valve so I assume it is open have used it 2 winters and heat works so must be open.
1968 c10
lowered 3" 4"
Old 07-31-2004, 08:37 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes if the heater is working, then the valve is open.
Does the truck have a/c? Does it work well? If it cools good enough then there is no reason why you can't remove the valve....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-31-2004, 08:42 AM   #8
76bonanza
76bonanza's Avatar
No a.c all a.c. parts have been removed.
1968 c10
lowered 3" 4"
Old 07-31-2004, 08:55 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Then we will have to assume the PO thought it would help keep the cab cooler during the summer. If you haven't shut it off during the summer you might give it a try. You may decide to keep it....
