Old 08-10-2004, 03:39 PM   #1
53burb
53burb's Avatar
Rearend
I have one more question. I would like to swap the rear out of my truck for a 12-bolt from 67-72. I have a '69 3/4ton 2wd Burb with an Eaton Rear & coil spring suspension. Will a 12-bolt with a coil spring suspension bolt right up w/o a problem?? Are the dimensions close enough for the driveshaft to work w/o being shortened or made longer?? What about the brake lines and Emergency Brake Cables?? Thanks for the help...Chris
53burb is offline   Reply With Quote
