Old 08-17-2004, 11:45 AM   #1
orangeuavol
GO VOLS!
orangeuavol's Avatar
Some progress
Almost ready to start it up and break in the cam. (the air filter is just sitting on the carb, still have to get my own)
408 BB (402 bored 0.030" over)
cam specs: valve lift, int. 0.503", exh. 0.528"; duration @ 0.050", int. 214deg, exh. 224deg; 112deg lobe spread.
Edelbrock Performer dual plane intake
Harland Sharp aluminum roller rockers
HEI w/ 50,000 volt coil
Quadrajet 780cfm
Speedpro pistons
9:1 compression
http://1972blazer.shutterfly.com/<= blazer build pics
It's called golf because all the other four letter words were taken.
It's easier to ask for forgiveness than for permission.
orangeuavol is offline   Reply With Quote
Old 08-17-2004, 02:36 PM   #2
Yukon Jack
Yukon Jack's Avatar
What kind of power do expect it to put out? Should motivate your K5 great.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-17-2004, 07:48 PM   #3
blazerholic
I am a Gov't Mule
blazerholic's Avatar
WOW!! Does anyone have a towel or moist towelette? LOL That's awesome man!
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 08-17-2004, 09:36 PM   #4
orangeuavol
GO VOLS!
output
Desktop dyno estimates about 415 ft-lbs @ 4500rpm and 398 HP at 5500rpm. Torque curve is very flat, 368 ft-lb @ 2000rpm. Exactly what I want for a 4x4...a stump puller!
Side note, my dad ran a desktop dyno on his 502 and it was very close to what GM advertised.
Old 08-18-2004, 06:25 PM   #5
71jimmy
71jimmy's Avatar
Okay, what's a desktop dyno and were can I get one?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 08-18-2004, 06:26 PM   #6
71jimmy
71jimmy's Avatar
By the way, really sweet motor!!!!!
Old 08-18-2004, 10:32 PM   #7
orangeuavol
GO VOLS!
Desktop Dyno 2000, its computer software for estimating the horsepower and torque curves based on the specs of the engine components you enter.
Had to do some rework. Found out that you shouldn't use the stock exhaust valve rotators due the added lift of my cam. I'm having to replace them a "anti-rotator" kit. luckily we can do that with out having to take the intake and heads back off. Any of you guys want to keep 'Murphy' at you house for a while?
Old 08-19-2004, 02:12 AM   #8
jhow66
jhow66's Avatar
Got mine here: (orangeuavol's dad)
http://www.sdpc2000.com/cart.asp?act...art&catid=1962
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-19-2004, 02:28 AM   #9
jhow66
jhow66's Avatar
Just did a more in depth check. Here's what it shows:
RPM--------POWER(FLY)---------TORQUE(FLY)
2000-------148------------------387
3000-------236------------------413
4000-------332------------------436
5000-------398------------------418
5500-------403------------------384
Old 08-19-2004, 08:43 PM   #10
blazerholic
I am a Gov't Mule
[QUOTE=orangeuavol Any of you guys want to keep 'Murphy' at you house for a while?[/QUOTE]
No thanx! His twin brother's been sleepin on my couch for years!!
