Old 08-18-2004, 11:09 PM   #1
imdarren
imdarren's Avatar
Timing light help / advice
What is the best "bang for the buck" when it comes to a good timing light.
I should keep it under $100 or so.
It would be great if you could recomend the brand model etc.
Any suggestions?
Thanks!
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 08-18-2004, 11:38 PM   #2
my new 72
faster, faster, faster
my new 72's Avatar
Anyt advance timing light is worth the money.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 08-18-2004, 11:42 PM   #3
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
I've had my Craftsman (one of these ) for over 20 years. $50 new from Sears.
Good, bright strobe, clip-on inductive pickup, long heavy leads. Wires unplug for storage.
SSOW...
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 08-18-2004, 11:43 PM   #4
skokie
skokie's Avatar
Not trying to steal the thread here but isnt there one that has a readout on it that tells you what the timing is set to or something like that?
skokie is offline   Reply With Quote
Old 08-18-2004, 11:48 PM   #5
imdarren
imdarren's Avatar
Good question Skokie!
It raises a good question . . . . are there some lights that have capabilities I should consider?
Darren
Washington State
Old 08-19-2004, 12:05 AM   #6
jlmtrout
Timing lights are all the same, they have an electrical power source (some are self contained battery powered, others use the car battery)they fire whenever the plug gets current from the distributor. Get one with an induction pick-up (clamps on the plug wire) and a bright light. The only other option is an advance knob on the back of the light that lets you "dial in" the amount of advance you want at a given rpm , it actually "fires" at the amount of advance you select. This can also be accomplished by using a timing tape on the harmonic balancer, just another way of going about it. Hope this helps. Go with a brand name you have confidance in and you won't be sorry. Good luck and keep on truckin'...................Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 08-19-2004, 07:04 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I have a Snap-On that has worked great for me since I began as a mechanic. I wouldn't have any other brand now. You'll pay dearly for the Snap-On label though.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-19-2004, 07:09 AM   #8
70c10
67-72 Addict!
70c10's Avatar
The Snap-On model is awesome but like Tx Firefighter said pricey- around $400-$500. Try harborfreight or somewhere like that and see what they might have. I need one myself!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-21-2004, 04:02 AM   #9
GMC Jim
GMC Jim's Avatar
Harbor Freight has a Timing Light -- Dial up to 60 degrees, inductive pickup, etc....seems to be worth looking into for the price of $29.99....( Part # 40963-OBNA)
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 08-21-2004, 08:08 AM   #10
68C15
blood type; Retumbo
68C15's Avatar
I bought my Ferret Instruments light from the local Car Quest about 4 years ago for $175ish. model no. 84. it has tach & advance up to 90*. nice narrow nose for fitting in tight spots & removeable inductive lead & a storage case. Matco tools sells them also if you have extra money to spend.
I know this may be above your intended price range but feel it is well worth it. how many do you plan on buying in your lifetime?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 08-22-2004, 02:28 AM   #11
687980chevy
687980chevy's Avatar
Sears Has 2or3 models,a cheapy made of plastic and 2 are chrome plated metal.One has dial advance but otherwise they are the same.Craftsman brand,good quality mine w/o advance dial was about $45.
68 K-10,79 K-10,80 C-30
57 chevy convertible
79 Z28
687980chevy is offline   Reply With Quote
