Old 09-06-2004, 08:21 PM   #1
71swb4x4
71swb4x4's Avatar
What do I set my timing at? 350 with TPI
I am setting the timing on my truck. I just put my TPI on my 350. Usually I set by sound, and then cruise around and make sure it isn't pinging, but I want a ball-park figure to set it at.
Is it any different with the HEI and TPI on it?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-06-2004, 09:10 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
disconnect the tan-black wire connector & set it @ 0*. turn engine off. disconnect batt for 30 seconds to clear the code 43. reconnect wire & batt. install bed, open gate, start engine, put in D, drive down here, do burn-outs!
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-07-2004, 09:48 AM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I set my Base timing at 6*.You can go anywhare from 6-10 base Timeing.(with TAN wire disconnected at HEI)
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 09-07-2004, 01:14 PM   #4
lock
Insert funny comment.
lock's Avatar
I like starting at 6 on TPI as well.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
