Old 11-15-2004, 10:20 PM   #1
co-necked
electrical help...
I'm having trouble with the white cloth wire. The main power wire from the harness to the coil. I thought it was my electric choke, I had it set up wrong. I fixed that and it still fries up. It seems like there's no power going to the distributor. I thought I put all the wires back the same I pulled. I got it going before I pulled the motor to put on some "accesories", now it won't start and frys that wire. Any suggestions? could it be i'm not grounded properly?
co-necked is offline   Reply With Quote
Old 11-16-2004, 08:48 AM   #2
JimKshortstep4x4
Smile
Somehow you are grounding the ignition wire, (shorting it). How do you have the starter solenoid hooked up?
Should be purple to inside and yellow to outside. Just a thought since you pulled the engine.
Jim
Old 11-16-2004, 12:40 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
From the - side of the coil to the distributor? any shorts? points opening?
(I) wire on starter solenoid shorting to ground?
sneakysnake is offline   Reply With Quote
