Old 11-20-2004, 02:13 AM   #1
skokie
skokie's Avatar
Vacuum Guage Setup questions
I got a few questions about a vacuum guage install. I know how to put it in but I am not sure on the best way to hook it up.
From the guage where do you connect the other side for vacuum? Is this a rubber or metal line?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-20-2004, 07:15 AM   #2
dwaite72lnghrn
It gets hooked up to a full vacuum port. I hook mine up to the drivers side of the edelbrock. Not sure on a Holly. Some folks hook it up to the manifold where it taps in behind the carb. Look for the lowest port (pipe) on the carb, The rear tap on most carbs are for power brakes, the bottom front is for the PCV, Both of these taps are 1/4"-3/8" and most gauges are smaller. On a Qjet and Edelbrock the lowest port on drivers side is full vacuum. The points distrib should be hooked up to this and a "T" connector will get you tapped in. At idle on this port you will have about 20" for a good stock engine. Hope it helps
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
