Old 12-30-2004, 11:02 AM   #1
Bowtie468
Bowtie468's Avatar
Lower A-arm question
Guys, once i bolt my lower a-arms back onto the crossmember, what is the best way to check that my cross-shaft is properly positioned (side to side) on the a-arm. Before i bolted them up, i roughly centered the shaft between the caps.
I just want to make sure i'm not 1 turn off or so before i button everything up.
Thanks !!!
Chris
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 12-30-2004, 02:53 PM   #2
Bowtie468
Bowtie468's Avatar
This may help explain the question ! Is there some measurement i can take between the crossmember and the cap? I understand that the cross-shaft is located in place by means of the dimple, yet rotating the shaft will cause the a-arm to move forward or rearward. This would directly affect caster, wouldn't it ?? This is what i am trying to properly position before installing springs and spindles.
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 12-30-2004, 04:36 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
There is a "shoulder" on the inside of the cross shaft. I just made sure the "shoulder" was the same distance (from the inside edge of the control arm) on both sides.
Keith
Convert to disc brakes.
Old 12-30-2004, 05:19 PM   #4
crazy longhorn
Fabricate till you "puke"
Its been a while since i did mine, so "bear with me" . if you run one of the bushings all the way tight in the arm, then scew the shaft in , till it stops....back it off 1 full turn(or till the locator hole is in the right spot for the pin on the crossmember). then screw the other bushing in, & down tight.....you should be pretty close. you can check this , by turning the shaft to bottom , against both ends, to find the center. after you are set, the scerws on the shaft /bushings wont move you too much.....just remember "center" as best you can, & the bottom arm is located with a pin. After that, its up to the alingment "dude" Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-30-2004, 05:39 PM   #5
SCOTI
SCOTI's Avatar
There should be a 'dowel' pin on the bottom of each front u-bolt mount that locates the shaft in the proper position. The trick is to align the 'dowel' w/the 'notch' in the shaft while aligning/tightening the u-bolts.
Looking @ the lower a-arm shaft you should see the notch (recess). If you look under your truck & you should see the 'dowel' as they're the same dimensions. Once they're tightened together, the arm is located correctly & the measurement won't change when pivoting the a-arm.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 12-30-2004, 08:29 PM   #6
Bowtie468
Bowtie468's Avatar
Sweet.. Thanks for all the valuable info guys !! Putting on the drop spindles as i type this
Many Thanks !!
Chris
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
