Old 01-03-2005, 02:29 AM   #1
Paso76GMCstepper
Paso76GMCstepper's Avatar
New Door Seals, Panels and window seals
Ok guys I have door seals window seals and new door panels coming. What am I getting into? I havent seen much writen on this subject. I want to do it right. I am replacing the vent window(wind wing) seals as well. If anyone can shed some light on this it would be great. I am replacing all the door seal on the cab. The anti rattle kit on the windows new felts.
Tony
"Life is a Team Sport"
To the memory of the Hendrick Motorsports Plane Crash Victims
Paso76GMCstepper is offline   Reply With Quote
Old 01-03-2005, 02:34 AM   #2
leastbay
the only think i have done are the felt thats on either side of the side windows its very easy to replace you just have to get the door panel off im pretty sure to do the vent seal you need to drill out the rivet and put a new one on after youre done i cant remember though maybe im wrong check into it in case you have to order the rivet
leastbay is offline   Reply With Quote
Old 01-03-2005, 09:11 AM   #3
odee
the vent windows will take some time to do, like said above the rivit will have to come out. Just be carefull with the glass, I broke two while doing this on a buddys truck.
odee is offline   Reply With Quote
