Old 01-14-2005, 02:05 PM   #1
low 84
low 84's Avatar
quick,, removing fender?
i'm about to go to the salvage yard in a few minutes and i'm going to be removing a fender. where are all the bolts at and are there any tricks i should know to make it easier on me. (this is for a 73-80)
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-14-2005, 02:17 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
From memory.
6 - across the inside of the core support.
2 - under the header panel (where hood latch is)
2 - core support/fender brace (where the front turn signal is.
1 - above door hing on the cab
1 - on the top of the cowl at the front (where the hinge is
1 - bottom inside of fender (cab to fender bolt
8 - inside lip of the inner fender.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
