Weekend Warrior
[B]Another "What's it worth"[/B]
Sorry guys i'm just curious as I can't make up my mind about anything anymore....
'69 SWB chassis with: -2.5" ECE dropped spindles -4" ECE dropped rear springs -ECE Rear shock relocator kit -ECE Adjustable Pan-Hard Bar -New MOOG Upper and Lower Ball Joints -New MOOG Pitman and Idler Arms -New MOOG Inner and Outer Tie Rods -New MOOG Upper and Lower Ctrl Arm Shaft Kits -'73+ PowerSteering Box -'73+ 5 Lug Discs -All the new Chassis stuff is for '73+ (cause it is cheaper and easier to get in junkyards) with the exception of the Upper and Lower Ctrl Arm Shaft Kits (which are for the 67-72) and the Rear Springs and stuff -Rear is Open Carrier 6-lug (gonna say 3.08's but i can check this weekend) -6cly motor mounts, no tranny crossmember, but i can include a set of small block mounts and an auto x-member Chassis is in very good condtion - no "rot thru", no major "pitting" with the exception of the Right Rear Trailing arm...and the only problem with that is that the two sides are seperating....i can cut the spot welds out and re weld it back together and it would be fine. None of this is put together (all New Parts still in thier boxes - I painted the Dropped spindles black though) - the chassis is rolling on the old front end parts as of now. It has not been cleaned/sandblasted - as i was going to clean it and use either POR15 or Eastwood's Rust Encapsulator on it. So if you wanted it powdercoated it is still in "virgin" form Any ideas on what it would be worth - i'd put it together and Paint it with POR or Rust Encapsulator if someone wanted. more than $1200 just in parts/shipping for the "new stuff" ???????????????? Thanks, Andy
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 01-25-2005 at 06:22 PM. |
