![]() ![]() Join Date: Jan 2005
FS: 67 Chevy SWB Stepside Truck
Model:
1967 Chevy C-10 Half Ton Short Wheel Base Step Side Two Wheel Drive Coil Spring Rear Suspension VIN: CS147Z Originally Equipped With 6-cylinder, Manual Transmission Engine: Mileage unknown, but no smoke and decent power 350 ci 3970010 Block (From 1974, I believe) 4 Barrel Quadra-Jet Carburetor With Electric Choke Edelbrock Chrome Air Filter Stock Intake Manifold Stock Heads (has some valve noise) Hooker Competition Headers Cam Shaft Most Likely Stock Long Water Pump Aluminum Crank & Water Pump Pulleys Chrome Alternator Brackets Stainless Flex Fan Mallory Magnetic Distributor Jacobs High-Output Electronic Coil Transmission: Rebuilt about 50,000 miles ago TH350 TCI Rebuild & Shift Kit High-Stall Torque Converter Two-Piece Drive Shaft With New Support Bearing & U-Joints Options: Power Steering Power Brakes (shoes/drums replaced about 20,000 ago) 3.73 Gears (no positrac, gear oil recently replaced) Gauge Dash Panel With Oil, Amps & Temp Other: Shoulder Harness Seatbelts Grant Leather Steering Wheel Sun Mini Tachometer With Custom Mount Sony AM/FM/Cassette Stereo (dash not cut) Four Speakers (two in dash top, two in dash bottom) Small Stereo Amplifier Dual Exhaust, 2 ½”, Crossover Pipe, Flowmaster 3-Chamber Mufflers Aluminum 15 x 8 Wheels Electric Windshield Washer Pump Welded Tubular Upper And Lower Front Suspension Control Arms (lowered approximately 4” in front) 4” Rear Lowering Coil Springs & ¾” Blocks Urethane cab mounts and suspension bushings Bicycle mount attached to bed floor Body: This truck had a professional frame-off restoration 12 years ago. There is no body filler thicker than 1/16”. The only visible rust in the truck when it was restored was in the rocker panels, which were replaced, and a small amount at the bottoms of the kick panels (new sheet metal was welded in). There are no dents to speak of on any of the panels. The panels all line up nicely with each other. Gaps between panels are straight. The driver door closes easily. The passenger door seals are a little stiff. Since then, the clear coat has started to peel on the left side of the hood, along the back edge of the cab, and on the bed rails. The grille has a lot of rock chips. The paint is worn off of the front edges of the bed steps. There are a lot of small chips and scrapes here and there in the paint. The windshield has minor pitting and one small chip, but no cracks. Rust spots have appeared on the lower corners of the driver door. The passenger door is perfect (it’s a ’72 model so it has an extra screw hole on the inside). Rust has developed on the bottom of the passenger bed fender. A small group of bubbles have appeared on the back of the cab on the passenger side where the floor is attached. There is a very small spot of rust on a seam in the bed side above the driver side step. The front bumper has a 1” spot where the chrome has peeled off. The chrome is pitted. The rear bumper is in perfect condition. The oak in the bed is showing its age, but is solid. A couple of the boards are bowed a bit at the ends. The driver side front inner fender has surface rust spots all over the inside of it where brake fluid damaged the paint. Tires: The front tires are 255-60R15 and have about 40-50% left. The rear tires are 275-60R15 and need to be replaced. Interior: No cracks in the dash pad. Pad is warped a small amount on the edges. Cloth/Vinyl seat upholstery is in decent condition. There are some minor cracks in the vinyl on the top edge of the seat back. Carpet has an oil stain on the left side of the seat (about 4” x 4”—hard to see since carpet is navy blue) Sun visor on driver side only Rear view mirror has some discoloration Truck History: I bought the truck from the original owner in 1992 in Northern California. The truck had an 80s bed on it so I replaced the bed with one that I found in the Sacramento valley that was from the correct year. I found a driver side bed fender from a long bed that didn’t have the spare tire cut-out. The original doors had some rust so I found two that were in better condition. I disassembled the truck and had all the parts media blasted. I then took all the parts to a local body shop to have the body work done, and to have the back sides of the panels painted. I then assembled the truck and had the body shop spray the rest of the paint. I replaced the door seals and the window seals. I have driven the truck every day for the last 12 years. I have put about 90,000 miles on it. The truck has been parked in a garage for the majority of the time I have owned it. I have been consistent about performing regular maintenance. I have all maintenance written down. I recently installed the motor. It was taken out of another truck I recently purchased. I’m not sure what the mileage is, but it doesn’t smoke at all when it starts or when it runs, even if it has been sitting for awhile. The engine does have some valve noise. I’m guessing that the valve rockers just need to be adjusted. The engine starts right up every time, and does not die when shifted into gear. All electrical systems work correctly. Asking Price: $3500 Delivery: I can deliver this truck up to 1000 miles for $1 per loaded mile. I’m in Colorado Springs, CO. I have about 50 pictures if anybody wants to see more Last edited by pjmoreland; 02-06-2005 at 02:04 AM. Reason: Make title more descriptive |
More Pictures
More pictures
Damn, that's one hell of a deal, someone needs to jump on this one!! At that price you shouldn't have any problem selling it.
Wow thats a great deal, I wish I hadnt invested in Eron. lol
Thanks Guys Adam |
sorry I cant spell. "Enron"
Thanks Guys Adam |
The LuvShack Garage
Thats about 1100 miles from me
![]() Did you mention AC ?
Rollin' in the 2dr Harley Hauler on Intro's |
Sorry, no AC. Wish it had it.
The nice thing is that Colorado is near the center of the US, so if I'm willing to drive 1000 miles, then it wouldn't be too much of a stretch for just about anybody in the US to meet me part way. |
There is quite a few good deals out there right now and im trying to sort them out. I think I would like to get those other pics sent to montytx@stx.rr.com if its not to much hassle. Also any other tid bits of info you may have. Thank you.
Jason
Jason--I will send you the other pictures, hopefully tonight, although it's getting late.
Deuce sent me a PM before you, so Deuce has first dibs. |
Also interested! Please send additional pics to timandmariela@cablemt.net Thanks!!
JUNK COLLECTOR!!!!!
you got enough projects, tim! though if you do get it, i'll trade the '55 for it! mwahahahahahahaha!
![]() ![]() The dark side! 2000 XLT PSD F-250 4x4! Offroad package 1970 C10 Short-step soon to be short fleet, maybe? Corvette in truck's clothing in work! Corvette IFS, IRS, TPI and Doug Nash 4+3 |
I sent pictures to 67Chev and THEPISTONHEAD. Please let me know if you do not receive them.
got'em....replied to email.
#15 |
The truck is sold.
#16 | |
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#17 |
#18 | |
#19 |
Once again....a day late, and a dollar short!!!
#20 |
Well holy S%#T, you actually did it. Congrats. Are you going to continue with the other one or part it out, just wondering by the TPI post?
#21 |
Going to use the motor out of this truck for my "dummy" motor in the "other" truck. Going to TPI this truck for the time being.
