![]() Join Date: Apr 2000
Need Info From 72 Service Manual
In the back of the book there is a page with Distributor specs. I need some info for the 402 or the 400 at the bottom of the page.
1 All the centerifugal advances, degrees and advance should be four 2 Vacume advance, degrees at HG should be two 3 Ignition timing, How many degress BTDC Then on the engine page can you give me the compression ratio for the 402. I have a 70 service manual but I have a 72 402 and want to see if there is any differance. Thanks Gary
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
