Old 10-24-2004, 10:07 PM   #1
Madbomber88
Active Member
Madbomber88's Avatar
Door Caps
Does anyone have a picture of how those rubber door caps are supposed to fit? I've put all new rubberstripping in my 71 and am down to the rubber window caps. I can't get them to fit the way they look like they should, and the old ones were never there so I have nothing to go on.
Thanks in advance.
-Tim
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 10-25-2004, 06:31 AM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Well this is on my 71 Blazer.Hope this helps.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 10-25-2004, 07:53 AM   #3
Madbomber88
Active Member
Thank you very much, that's exactly what I am looking for.
Do you have any leaks with yours?
71 Blazer CST
72 K20
Capt USAF
Old 10-25-2004, 09:49 AM   #4
BobbyK
BobbyK's Avatar
minor ones with light rain.Moderate with heavy rain.
I think GM was on a 420 break when they designed that area of the top.
I think they leaked from the factory.
Old 10-25-2004, 11:52 AM   #5
71jimmy
71jimmy's Avatar
Excuse the intrusion:
Bobby K, in the top and bottom picture you posted, I've never seen that piece. Is it part of the rubber seal of the top or is it a separate piece? Looks like it srcewes to the windshield frame as well as the top. I've never noticed holes for those in mine but then again didn't know to look.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 10-25-2004, 02:43 PM   #6
AK|Bandit
AK|Bandit's Avatar
I also have these on my '72 blazer. I'm pretty sure the seal in the top picture is part of the weatherstripping, but the one in the bottom picture is seperate piece. I cant remember the name of them. Drip rail deflectors maybe???
It's better to wear out than rust out!
AK|Bandit is offline   Reply With Quote
Old 10-25-2004, 03:13 PM   #7
71jimmy
71jimmy's Avatar
Dang you guys something else I didn't know, don't have, and need to look for!!!!!
Anybody know if these were only on '72? In which case I don't need on my to get list.
Old 10-25-2004, 05:08 PM   #8
Madbomber88
Active Member
I think they were on all first gens. The rubber pieces can be bought through LMC for like $36 a pair. They are separate from the weatherstripping and screw to the top and the windshield frame. I'm not so sure about the plastic door caps, I haven't seen them for sale.
71 Blazer CST
72 K20
Capt USAF
Old 10-25-2004, 05:40 PM   #9
71jimmy
71jimmy's Avatar
Thanks, just looked in my LMC cat., your right. I just never new to look for them, never seen them on a Blazer. As to the plastic door caps, I believe www.****************.com is making them, I think $25 apiece.
Later
Old 10-26-2004, 01:08 AM   #10
BobbyK
BobbyK's Avatar
That rubber drip rail gets screwed into the top and the winshield frame.
When the top is removed you just remove the screws in the winshield frame.
Old 02-27-2005, 11:16 PM   #11
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Can these door caps be installed without removing the top? ie. My Blazer is missing them, and I don't want to remove the top right now.
badpeanut is offline   Reply With Quote
Old 02-28-2005, 01:53 AM   #12
BobbyK
BobbyK's Avatar
No need to remove the top to install the drip rail deflectors.
