Old 03-19-2005, 06:17 PM   #1
1980chevy4x4
Got Mud?
No speedo...
So there i was crusing around in first gear reving it up scarin old ladies when i look down and see the speedo is not working....so did i break maybe the cable or is it something more serious??
Dan
Got mud?
1980chevy4x4 is offline   Reply With Quote
Old 03-19-2005, 06:38 PM   #2
Russell
Professional Grade
Russell's Avatar
Either the cable broke / came undone, or you busted your speedo, both of which are cheap any easy to fix
I guess, there is the possiblity you broke the plastic gears in the tranny, but those are also cheap and easy to fix as well
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-19-2005, 10:58 PM   #3
1980chevy4x4
Got Mud?
do u have to pull the trans out to fix them?
Dan
Got mud?
Old 03-19-2005, 11:46 PM   #4
Russell
Professional Grade
Russell's Avatar
Nope Its on the side where the cable goes in Just remove the plate, and you'll see the gears behind there.
Old 03-20-2005, 02:30 PM   #5
1980chevy4x4
Got Mud?
Aight ill have to check that out..
Dan
Got mud?
Old 03-21-2005, 06:50 AM   #6
ureckme
ureckmefixit2@cox.net
Do you have cruze, some times that will break the cable. Matt
ureckme is offline   Reply With Quote
