Old 03-19-2005, 01:07 AM   #1
frost89434
frost89434's Avatar
question about dynamat
I was thinking of not replacing the 3 pads on my firewall and instead I was going to use dynamat. Would this be ok or am I still going to need the firewall pads? Any help would be great. Thanks JIM
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 03-19-2005, 01:45 AM   #2
muddpile
muddpile's Avatar
I'd do the dynamat then put the pads back or add some other padding. The more deadener the better, and dynamat and padding do different jobs. Dynamat stops panel vibration and resonance, while the padding acts as a sound absorber.
muddpile is offline   Reply With Quote
Old 03-19-2005, 01:53 AM   #3
frost89434
frost89434's Avatar
Thanks for the info. I was kind of hoping to be able to do without the padding. The new pads are over a 100 bucks. I can dynamat the whole cab for about 130 or so. I guess I am just being cheap.
Sparks, Nevada
Old 03-19-2005, 10:58 AM   #4
kaycee
kaycee's Avatar
Exclamation
$100 WHERE U BUYING IT? I just got my pad's for $50 drvs. side, center and passed on the pass. side cause the A/C takes up all that space.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 03-19-2005, 12:48 PM   #5
frost89434
frost89434's Avatar
Where did you get yours?
Sparks, Nevada
Old 03-19-2005, 06:15 PM   #6
shifty
Questionable
shifty's Avatar
Not to be argumentative, but I think they're basically the same thing .... both products add additional weight to the panel, which not only acts as a sound barrier, but primarily makes the panel heavier leaving it less prone to vibration (which would allow sound transfer, kind of like a passive radiator)
I believe it's all the same concept. I completely agree "the more, the better" You can never have too much sound deadener anywhere.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-20-2005, 01:22 AM   #7
mocwon
Keep On Truckin'
mocwon's Avatar
I'd just use the Dynamat, in fact, that's exactly what I did. I can't imagine you would need both. The Dynamat absorbs the sound as well as the heat. Mine's not on the road yet so I hope this was a wise choice.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 03-20-2005, 11:20 AM   #8
greasemonkey
greasemonkey's Avatar
I used Brown Bread and firewall pads, I only used one layer of BB but I might put some more on the floor and rear wall.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 03-20-2005, 01:31 PM   #9
kaycee
kaycee's Avatar
Got mine from Kenny's Truck's out of Oklahoma www.kennystrucks.com
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 03-20-2005, 04:05 PM   #10
1STtimePRo'71
1STtimePRo'71's Avatar
Accumat is cheaper than dynamat and I just bought the rest of what WalMart had on the self here for around 60 bucks. I got 8 packages of it and 1 pack will do the whole inside of a door. Just my .02 on the "cheaper" thing.
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 03-20-2005, 04:12 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I used FatMat in my 66 Chevelle, that I purchased thru ebay for $100 for 100sq. ft. I haven't drove the car yet to notice a difference, I'm just stating that there are other alternatives to Dynamat.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 03-20-2005, 04:39 PM   #12
70short
1STtimePRo'71 How many square feet did you get??
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 03-20-2005, 05:49 PM   #13
Kid
Kid's Avatar
I think you should not forget the factory type fire wall pad, or aftermarket carpet insulation.That is needed for heat/ cold insulation . The sound dampener material does nothing for insulation.
Kid is offline   Reply With Quote
