I've been lurking around a while, then got caught up in moving, so I guess you could say this is my first REAL post. Unfortunately, it's a cry for help for the experts I've seen in action here (and everybody else as well)
![]() I've got a 72 Cheyenne LWB, 3 speed on the column, with a 307 that the guy I bought it from put in it, and it still has a points distributor as well. I think my problem started back around November when I drove the truck home to Virginia for hunting season. It has just recently gotten noticeably worse, but that may be because I've started a 30 mile/day commute, and the truck is my daily driver. The only way I can describe it is similar to a big gust of wind hitting/slowing the truck down intermittently when I'm pulling a grade, and a little noticeable at higher RPMs before shifting (but not alot). It feels like it just kind of lags or cuts out. Not the engine, but more like maybe clutch or tranny. On level ground it doesn't do it at all except maybe a hint at the higher RPMs, but I try to shift way before that due to my feable attempts to save gas ![]() If anybody has any thoughts, please feel free to dump them on me. I wasn't sure where to put this thread, so I just thought I'd start it here. Moderators, fell free to move it as applicable. Thanks ahead of time for any help. 'Preciate it. Doug
Doug Simmons 1972 LWB Cheyenne- blue w/ white top 1998 Z28 Camaro (quicksilver) |
Sounds to me like you've got a clutch slipping. RPM's go up, speed goes down. Did you say the engine sounds ok during all of this?
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
Have you done a compression test? Maybe that 307 has lost just enough to poop out at higher rpms pulling a load. You wouldn't notice any difference standing in the driveway buzzing the throttle because there isn't any load on it.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Might be an idea to see what a clutch is worth. I'm and automatic guy so I have no idea what the parts would cost, but if you could get some help it would likely be not too much to put one in yourself. If your gonna keep the truck with the 3 speed that is. Even if you bought the parts & pulled things apart and the old one looked good you could take the parts back if you didn't need them. My last standard was a VW beetle with a fairly warm motor and a new clutch was a good investment I thought even tho the old one wasn't totally gone. I'm not an expert tho.. Good luck & welcome from the great white north.
I got a bench seat baby, you don't have to sit over there. |
Yeah, I vote for the worn-out 34 year old clutch too, does the engine feel like it's revving up on longer hills under a load,? (that would be the clutch slipping) The parts wouldn't probably cost more than a couple hundred bucks, and depending on your own mechanical skills you could probably do it yourself if you have access to a hoist, I don't think you would want to attempt a clutch change lying on your back in the driveway or shop,(you'll have to drop the tranny out) and you'll want to get the flywheel re-surfaced (ground) at a machine shop. Also that would be a good time to replace the rear oil seal if needed.Good Luck.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
Hey guys. Thanks for the inputs. I notice no change in the RPMs, it pretty much stays the same. If anything it seems like it may drop off a little. I'm probably going to try the compression check. I need to change valve seals anyway, so between both jobs it'll give me a reason to pick up some tools.
I've priced a clutch setup, and it doesn't seem too awfully bad. Any ideas on what clutch dia. size/spline count I'd have? I can get plenty of assistance, so I could probably do it myself. I was worried that the truck might start showing some signs of old age when I started this commute. It might be just about time to pull the cover off the Z and do a little work on the truck. Any more comments are welcome, and thanks again. ![]()
Active Member
When was the fuel filter changed? If the filter is clogged, your 34 year old fuel pump may not be producing enough pressure/volume to overcome the resistance of a clogged filter and the carb bowl runs out of fuel. It is realy noticeable when you try and see how far you push to find where "E" is on your fuel guage.
IMO, Sonny |
![]() Just my $.02 |
its all about the +6 inches
You tried a tune up?
I agree that your clutch is most likely fine. |
Thanks again fellas. I've got a 3 dayer next weekend, so I plan to do a little wrenchin. I may even go snag a fuel filter tomorrow and try it. I haven't changed it in my 2 years of owning the truck. I had actually thought about it before, but figured I'd be able to see it more often than just under a load. But hey, a complete tune up sounds doable.
![]() Join Date: Apr 2000
I vote on thr gas filter.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Killin' Time
My truck had similar problems, fuel filter fixed the problem. Before I bought it, the truck sat for 2 year. I changed the filter right when I bought it, and then didn't think about it as I drove it for a few months. Well, all the dirt that accumulated in the 2 years came out in the first few months I drove it. The fuel filter was totally clogged. Fuel filters are cheap, and easy to change, so if it hasn't been done in 2 years, definately try it.
NEED CORVETTE 1972 GMC C20 350, SM465, HEI Dynomax headers and 2.5" duals |
Franko72
I would change the plugs and points if it has points, Maybe cap and button. I vote for a tune up like longhorn man suggested before I did anything else
![]() 1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
Check the sock in your gas tank too, mine was clogged and cause a similar problem.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
#15 |
Questionable
If this also happens when you stomp on the gas (like...when you're passing someone), I'd also say it was a gas filter. Cheap part, too. World of difference between a clogged one and clean one.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
#16 |
Yeh guys, I changed the filter (gas and air), fuel and vacuum hoses today. It does run better
![]() Again, the motor doesn't actually sputter or break up. I'm just trying to eliminate any other possibilities before I tackle the clutch. Thanks for the comments/suggestions. This place is a great source of info ![]()
#17 |
forget them points. throw in an hei especially driving 60 miles minimum a day those points will be way more trouble than they are worth. you should be able to get a used hei for around 35 or 40 bucks put on a new cap and rotor and run a new power wire and you will be good to go. also need new ignition wires for the swap as well as plugs but thats all normal tune up stuff anyways.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
#18 |
Cableguy is sssssssssooooooooooooo right. Get an HEI in that thing. It can't be a clutch problem, or the RPM's would go up while speed goes down. HEI, wires, cap, rotor, plugs and you'll be good to go for a LLLOOOOONNNNNGGGG time again.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
#19 |
Thanks busterrrrrrrrrrrrrr
#20 |
i have a stock unit that worked when it was pulled a couple years ago it would probably need a cap and rotor otherwise good if u would wanna come get it i will let ya have it for 30 bucks
