Old 04-06-2005, 03:58 PM   #1
mvpco
Charging system info needed
HI All!
My charging sytem is not working right.
1972 Chevy C-10 350, auto I put new alt, voltage reg.(solid state) I check voltage at Terminal 2 and it is 12 volt and bat volt at battery connection is 12volt what should voltage at terminal @1 be on Alt???
any other ideas?
Generator light stays on at idle, but when I rev it up it goes out????
Jeff Smith
Pensacola, FL
mvpco is offline   Reply With Quote
Old 04-06-2005, 04:21 PM   #2
dubie
dubie's Avatar
could be your battery? When the truck is running and you have a voltmeter on the right battery trminals, you should be pulling over 14 Volts at idle. If it's about half that, then your battery is screwed. I had this happen last fall on mine, ended up being a DUD battery. Usually when one part of your charging system starts to go, the rest will follow.
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 04-06-2005, 07:12 PM   #3
mvpco
Charging System
I also put a new battery in and forgot to mention, thanks
I found a old post about it at:
http://207.44.196.117/vboard/showthread.php3?t=119379
great info all around
lots of great info, this board is better than the old military jeep board I use www.g503.com
Jeff Smith
Pensacola, FL
mvpco@yahoo.com
Old 04-06-2005, 08:49 PM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Term 1 is the voltage sense line.
NO voltage should be present.
This terminal tells the alt to start chargeing.
It's take's a "sense" of the voltage being used by the electrical system and tells the alt to either produce more or less voltage via the internal voltage regulator.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-06-2005, 09:40 PM   #5
aesj2
Check the fuses under the hood, along the fenders near the front. These are in black holders. They are used for the charging system. I think they are 5a and are used for the gauge circuit.
aesj2 is offline   Reply With Quote
Old 04-07-2005, 02:34 AM   #6
BobbyK
BobbyK's Avatar
Those are for the Amp gauge only.
Even if both those fuses are blown the charging system will still work.
Old 04-07-2005, 08:08 AM   #7
mvpco
Charging System
I did it, no problems, WOW!
Great info
Jeff
Pensacola
Old 04-07-2005, 12:22 PM   #8
BobbyK
BobbyK's Avatar
I mistakenly stated that term #1 "sense's" voltage.I'm sorry but that would be terminal #2.
Term. #1 only "turns on" the alt. and tells it to start charging.It also can operate the "ALT/charger" idiot light if don't have the gauge inst. cluster.
Sorry for the misinformation.
