Old 04-06-2005, 11:43 PM   #1
screamin_c102
screamin_c102's Avatar
White face and LED conversion
I white-faced Screamin's gauges and installed red LEDs as dash lights.
The gauge in the "blank" spot is a dual needle air-ride PSI gauge for the near future Air ride system.
I need to get a new clear lens as mine has about a million hair-line cracks in it.
The pictures suck but ya get the idea.
screamin_c102 is offline   Reply With Quote
Old 04-07-2005, 12:36 AM   #2
shifty
Questionable
shifty's Avatar
Those are sweet, but I'm a huge fan of blue. I'd prolly go green b/c of the colour of my tuck.
Ok, OK, where's you get em? Damn I need a tach dash!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-07-2005, 12:40 AM   #3
screamin_c102
I made 'em the LEDs that is, the overlays are from Durange Design $20.00 on Flea-Bay.
Old 04-07-2005, 12:50 AM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
ok how did ya make the leds? and was the white hard to do ? did ya have to order the white part that go's on the lens extra ?
tnblazerk5 is offline   Reply With Quote
Old 04-07-2005, 12:56 AM   #5
screamin_c102
The lens has the numbers on it an it sits in front of a blank metal piece (bezel) that houses the gauges. You paint this piece white with el-cheapo rattle can. Then the vinyl overlays go on the gauge face itself. It took about two hours to clean up everything and to scuff the metal bezel for paint. It really isn't that difficult.
Old 04-07-2005, 12:59 AM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
oh ok i havent had a bezel apart yet to see what all is in there lol and i am also doing the comaro tack thing too so how did ya make the L.E.D.s ?
Old 04-07-2005, 01:07 AM   #7
screamin_c102
I ran 4 LEDs for the large gauges and one each for the small gauges. These ar all wired in a parallel circuit with a 600 ohm 1 watt resistor in the positive lead. I drilled the pressure gauge for the its LED and the others are hot glued to the bezel, just at the lip. I have to take it apart to move the LED on the water temp because it is too close to the lip and you can axctually see it.
I figured the resistor by using a source of 13v then divided the 200 milli-amps into it to get a base resistance. Then I went up or down in resistance until I found the brightest value.
I tapped into one of the factory bulb holders and soldered my positive and ground to it. By doing this I can dim them like normal. I also modified the signal indicators and installed single green LEDs into the factory 194 bulb holders.
Old 04-07-2005, 01:16 AM   #8
tnblazerk5
User #12137
tnblazerk5's Avatar
i have no clue to what all you just said but to it !!!!!!!!! i dont know that much about L.E.D.s to know what all is going on with them but i want to learn about them cause that dash you did looks great and i would like to do the same thing to mine but with a diff color bulbs !!!!!!! do they make any L.E.D bulbs that go in place of the orginal bulbs ? and if they do can they be dimed ?
Old 04-07-2005, 01:22 AM   #9
screamin_c102
I tried replacing the original bulbs but they are mounted in the rear of the cluster. This didn't work because LEDs have a directed beam of light not like bulbs that glow in all directions. I messed with that idea for a while and gave up, because the panel was way too dim, and looked like crap. The truck sop sells a conversion bulb that will fit the socket, but it is too big in diameter to fit through the hole.
I'll draw up a diagram tomorrow at school in AutCAD.
LEDs are easy to work with once ya get the hang of it.
Old 04-07-2005, 01:27 AM   #10
tnblazerk5
User #12137
tnblazerk5's Avatar
ok cool can i have a copy of the diagram after you get it done please ??!!!! i want to learn about this things lol
oh did ya take any pics while you was putting it togeather ?
and thanks for the heads up on the stock to leds thing !!!!!!!!!
Old 04-07-2005, 01:29 AM   #11
Blue4x4
Blue4x4's Avatar
Looks great. I like the psi gauge. But was wondering if there any way to remove the factory lines on the old lens so it doesn't interfear with the psi numbers and lines?
Blue4x4 is offline   Reply With Quote
Old 04-07-2005, 01:30 AM   #12
screamin_c102
Sure, Ill post it on the board, As far as pics, That would have been too easy
Old 04-07-2005, 01:31 AM   #13
tnblazerk5
User #12137
tnblazerk5's Avatar
lmao on the to easy thing !!!!
cool on the posting it thing !!!!!!!!
Old 04-07-2005, 01:36 AM   #14
Russell
Professional Grade
Russell's Avatar
Personally I'd have gone with light blue LEDs And I probally would have stuck a fair number more around each gauge
Looks awesome though man!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-07-2005, 01:41 AM   #15
screamin_c102
I'm probably gonna add more around the speedo and gas gauge, I have some clip on two prong computer fan connectors so I can just keep addin' until I'm happy with it ::
I went with red 'cause Screamin' has a red and white theme.
I have red lighting throughout the cab. Any color LED can be used, blue and white are the most expensive though.
Old 04-07-2005, 01:42 AM   #16
nathan_454
looks good guys.. I did the white faces in my blazer... i didnt do leds, i painted the needles blue with testors model paint... i like the results. here are some pics.
forgot to mention i also painted the inside of the bezel and around the outside white.
nathan_454 is offline   Reply With Quote
Old 04-07-2005, 01:43 AM   #17
tnblazerk5
User #12137
tnblazerk5's Avatar
i am going to use Meguires plastic cleaner to clean the lines off for the comaro tac thing
Old 04-07-2005, 01:46 AM   #18
screamin_c102
Looks awesome!! I love how the white face classes up the stock cluster.
Old 04-07-2005, 01:47 AM   #19
69 Short Fleet
sceamin > Looks very cool! My lens was really bad when I redid my gauges last year (many, many scratches) and I went over the front of it with "autosol" metal polish (tooth-paste tube type, as I've found the liquid type they make is not as good) and the stuff works excellent on plastic as well as aluminum. Doug
69 Short Fleet is offline   Reply With Quote
Old 04-07-2005, 01:48 AM   #20
tnblazerk5
User #12137
tnblazerk5's Avatar
did you use a L.E.D bulb in your dome light too ? if so did you have to use the resistor there too ?
Old 04-07-2005, 01:53 AM   #21
nathan_454
thanx for the comments. i also changed the lenses in my blinkers to blue, so they glow blue now
Old 04-07-2005, 02:51 AM   #22
5150
C10 Club Tennessee
5150's Avatar
I bought 8 Blue LED's from this site here:
http://www.superbrightleds.com/cgi-b...gi?product=CAR
I bought 4 of them for my dash and 4 of them for my sidemarker lights. I was told that I could just plug these into the little black holders on the back of our gauges. They are wide angle so they are supposed to put out a lot of light.
Could be wrong. Correct me if I am.
Love the red Screamin
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-07-2005, 06:55 AM   #23
byrd
Union Electrician
byrd's Avatar
It's alot easier if you you 3000# grit wet sand paper. Soak the paper for 1/2 hour before using.It will take those lines off in no time at all. Then you can use the cleaner and polish to get the scratches out. jmo Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-07-2005, 09:31 AM   #24
oj70chevy
250 V-6 Club
oj70chevy's Avatar
[QUOTE=yellow69]I bought 8 Blue LED's from this site here:
Yellow 69, can you post some pics when you have it done. and let us know what you think of the leds? also if you have any problems with the install.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 04-07-2005, 10:16 AM   #25
screamin_c102
Thank you,
The bulbs you bought are pre-modified units designed to fit our black holders. inside the base there is already a resistor and the LEDs. I made the same basic thing and could not get enough light to "bounce back" onto the gauges. I say install 'em.They might be brighter than mine were, I dunno.
One bonus to my setup I forgot to mention.....it was free, well minus the grand I pay in tuition each semester
