alternator...grrr....
Hey y'all got a quick question,
o.k. my 71 has a 77 454, now I didnt set this motor up to be near a stock one. with msd, and hei distrubtion, I was wondering what size, amps that is, alternator I should be trying to run, because the alternator I took out of it today has lasted 7 years, not to sure what it was, but it lasted obviously. anyways, what size alternator should I be running to be on the safe side, pretty sure that having msd on it would change my "amperage intake" What yall think? What size alternator would I be trying to push? thanks, chris
~Christopher L. Orr 71 c20, 454- Stolen While Deployed. dynoed at 550 ft lbs, 425 hp at 3000 rpm (mustang dyno). TH400 3500 stall.... etc, etc. |
got boost?
if you have an amp guage that displays actual numbers you can figure it out quick.should be 200 amp guage or close.
first & more importantly, check & clean all your electrical connections; grounds from frame to batt, frame to cab, etc. a strong alternator will simply heat the poor connections leaving you with a puddle of plastic & low voltage. now, wire the amp guage in line on the negative side near the FULLY charged battery. turn on every electrical device on your truck.the w/s should be wet for the wipers.the ign. is already rated by the manufacturer so you can figure that in later. don't forget the b/u lights. write the reading on the amp guage down. add the full amp rating of the ign. multiply by 1.25. this will give you a 25% safety margin over everything. i would suggest staying away from parts house rebuilt alts.the only thing you know about them is they are cheap. go with east coast electric or some similar co.or maybe a local starter alt shop. or you could just throw a good 140 amp at it. ![]()
'70 chevy lwb w/'67 hood. 357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada..... '82 honda v45 sabre"the black" ![]() |
i agree with chevibubba.. I bought a used 6/12 config. alt from junkyard for $10..then local alt shop rebuilt it up to 120 amp for $30, so I only had $40 in it.... a 90 amp delco was like twice that price....just my $.02
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
