Majician
12 bolt to 14 bolt FF questions.
I have a '72 C10 with the 5 lug coil spring rear. If I swap in a 14 bolt FF axle (3.5" axle tube diameter) can I still use my control arms? Are the u-bolts holes through the arms spaced far enough apart for a wider u-bolt? I know of needing a panhard mount and spring pads , but I'm not sure if my control arms will work.
Thanks. |
