Old 04-02-2005, 10:38 AM   #1
bigred66
bigred66's Avatar
Question crossmember??
What years use the same front crossmember? Could I take the crossmember out of a late model and put in to my 66? What years will work? I am planning on doing a cross member drop, and brake conversion, and drop spindles. Could I do this to eliminate the need for a brake conversion since I have to take it out any way?
bigred66 is offline   Reply With Quote
Old 04-02-2005, 04:27 PM   #2
mkundo
To my understanding the '73-'87 cross member will work with your '66. Now if the i/2 ton is different than a 3/4-1ton I would not know. Hope this help's
MK
mkundo is offline   Reply With Quote
Old 04-06-2005, 12:54 PM   #3
bigred66
bigred66's Avatar
Any one else i dont think i am going to do the crossmember drop now.
Will i have any issues if i take my crossmember out will say a 84 bult right up?
Old 04-06-2005, 02:51 PM   #4
neonlarry
neonlarry's Avatar
It should fit fine except for two bolts. You will have to elongate the holes to get those two bolts to fit. Also IIRC you will probably have to do some bending to get the brake lines to hook up.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 04-06-2005, 03:38 PM   #5
bigred66
bigred66's Avatar
thank you every onei need all the help i can get
Old 05-14-2005, 05:06 PM   #6
67-Cowboy
67-Cowboy's Avatar
A buddy of mine put the whole front-end out of a '77 under a '66 and he told me everything bolted fine accept two rear bolts that he elongated the holes on. So Neonlarry is telling you the straight scoop !!!
67-Cowboy is offline   Reply With Quote
Old 05-15-2005, 12:12 AM   #7
chevy283
chevy283's Avatar
i just put a 91 sub in my 65 their are 4 bolts that dont line up 2 on each side I switch the idler arm with the 65 and that work.
chevy283 is offline   Reply With Quote
Old 05-25-2005, 02:29 PM   #8
72c5
72c5's Avatar
What about something newer like a 95? Anybody try that? hogging out a few holes is no big deal.........
72c5 is offline   Reply With Quote
Old 05-25-2005, 05:31 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
After 1987, the control arms are bolted to brackets that are welded on the top of the framerails and the crossmember is actually a welded structure on the frame.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
