Old 05-13-2005, 10:43 AM   #1
mingoman
Question Grill Repair
Has anyone ever tried to repair one of these grills? I want to use the '76 grill on my '78 Big 10 and have one with all the chrome trim thats perfect except for one small piece thats broke out. What would be the best way to repair this? I need a 454 grill emblem also, are these the same from '73 up? Thanks in advance. Mingoman
76/77/78 Cheyenne
1997 K3500 454 soon to be 496
mingoman is offline   Reply With Quote
Old 05-13-2005, 11:20 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I was looking into this a while back. I found a site on the internet about grill repair. They said that, if you have the broken out pice, you can glue it in with plastic model cement. I believe they touched it up with Bondo, and repainted everything with Krylon "Dull Aluminum."
If the broken part is chromed, it will be harder to cover up the repair. Of course, I was able to buy a replacement from a local "Crash Parts" type place for mine for $24, so I never tried to repair it. You might be able to do that.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-13-2005, 12:57 PM   #3
mingoman
I didn't think about model cement. I don't have the peice that is gone but I was thinking about getting a broken grill from a yard and cutting out the peice I needed. I was thinking about trying fiberglass from behind the grill then fill in the front. I haven't been able to find a good '76 grill around here so I think I'll try and fix this one and see how it turns out. Thanks.
76/77/78 Cheyenne
Old 05-13-2005, 01:12 PM   #4
Slonaker
Slonaker's Avatar
I used the Krylon Dull Aluminum to paint my headlight bezels based on what was said on that site. It was a perfect match to the grill.
Slonaker
Stock '01 Silverado
Old 05-13-2005, 08:08 PM   #5
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
The '73-'74 emblems are smaller than the '75-'76.
Joe
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 05-16-2005, 03:50 PM   #6
mhicks
mhicks's Avatar
I found a brand new grill on E-Bay for my '73 and ended up paying 49.50 for it. Did I ever luck out. It was still in the original GM box. That was sweet.
mhicks is offline   Reply With Quote
Old 05-16-2005, 07:34 PM   #7
Bagd74Jimmy
I wouldn't use fiberglass, use Duramix 40/60, it's for plastic repair, will work better than fiberglass. Most autoparts stores sell some kind of plastic repair material, it usually comes in two parts, material and catalyst. When you mix it, don't play around with it, just mix it a little and apply it.
1974 GMC Jimmy ( on 'bags by the end of summer )
1959 Chevy LWB Stepside
Bagd74Jimmy is offline   Reply With Quote
Old 05-29-2005, 01:44 AM   #8
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Slonaker
Where did you buy it? None of the stores here have any aluminum paint.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 05-30-2005, 11:41 PM   #9
Justins76
Justins76's Avatar
Found it. Ace got in 2 cans so I bought both
I uses some 5 min epoxy to fix the crack in my grill.
My cardomain page
Old 05-31-2005, 12:16 AM   #10
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Krylon has changed the name of the Dull Aluminum to Bright Silver Metallic I think.I used it o a project a while back and it works great.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
