Professional Grade
Progress Report!
Woohoo! Got all my electrical on the interior done today! The TPI harnesses are working perfectly, and less the seatbelt light, the entire truck's harness works now as well (I am fairly sure the seatbelt light is just something loose, as I did see it work tonight). Even got my remote door lock controller / remote starter working as well
![]() Tommorow I will put the interior back together, maybe I can actually sit in my baby tommorow ![]() All that is left before I can fire the TPI up is a heater hose that goes between the lower intake and the throttle body, a thermostat housing, an upper rad hose, install the electric fans, fuel lines, and to install the Suburban tank. After the engine is running, it will only be a matter of days before I can have the truck back on the road ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Chevys Kick A$$
Making some damn good progress. Going to be sweet when its all done. Where are the pics at?
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
Yea, let's see some pix. It sounds like you did a good job, show off time!
Go Fast - Be Loud |
Professional Grade
Pics are coming tonight
Im definatly going to have to visit you this fall when you got that baby done!
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
