Old 07-23-2005, 03:34 PM   #1
Avenger
Smile Eaton No-Spin Detroit Locker - Best offer - pictures!
17 Spline. $300 or best offer plus shipping.
Avenger is offline   Reply With Quote
Old 07-25-2005, 09:53 PM   #2
masterbeavis
Having issues
masterbeavis's Avatar
This will fit an eaton 14b HO52, or HO72. OR will fit into a 14b if you use the eaton axle shafts.
Bump for ya brutha
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 07-25-2005, 09:58 PM   #3
Avenger
I have an extra set of Eaton axle shafts I can throw into the deal if needed.
Best offer gets it.
Old 07-26-2005, 02:03 PM   #4
Avenger
Pictures added.
Old 07-26-2005, 03:00 PM   #5
Alex Hayley
I don't know much about differentials. Would this fit a 12 bolt differential?
Alex Hayley is offline   Reply With Quote
Old 07-26-2005, 07:06 PM   #6
Avenger
No, only a 14 bolt or Eaton axle.
Old 07-26-2005, 07:08 PM   #7
Alex Hayley
Avenger, thanks for the response!
Old 07-26-2005, 09:14 PM   #8
So this works on Eaton HO52 and HO72 and later 14-bolts w/the Eaton shafts you have?Does it work with all ratios?I`m headin`out of town`til monday.I`ll check back.
Old 07-26-2005, 10:38 PM   #9
Avenger
What you said is correct. The ratio does not make any difference because you do not change the actual ring gear carrier. The locker goes inside your existing carrier. It will bolt right into all Eaton and 14 Bolt axles without reseting the ring and pinion. All you have to do is keep track of the carrier bearing adjustment nuts. It is very easy to do and here are some very detailed instructions:
http://www.off-road.com/chevy/tech/detroit/
For the 14 bolt you do have to run the Eaton axle shafts (which I will thrown in for Free if needed). You have to change them because the 14 Bolt and Eaton axle shafts have a different spline count. Otherwise the axle shafts are identical in both length and thickness.
BTW: There are 3 different length 14 Bolts (63", 65", and 70"). The Eaton axle shafts I have will fit all 14 bolt axles except the extra wide 70" 14 Bolt's that came in Vans.
