Old 11-20-2005, 10:42 PM   #1
Striker169
Car O'Holic
Striker169's Avatar
Exterior Trim and Paint Colors
What trim packages came in 69? and what two tone combinations were avalible? Would my truck bed be a 69 option?
Striker169 is offline   Reply With Quote
Old 11-20-2005, 11:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Exterior Trim and Paint Colors
That could be a 69 - 72 bed.
Trim packages included custom comfort and appearance, custom, and custom sport truck
Old 11-20-2005, 11:58 PM   #3
Striker169
Car O'Holic
Striker169's Avatar
Well basicly what im asking is if I made the front of the truck the same would that be year correct for a 69?
Old 11-21-2005, 12:06 AM   #4
Longhorn Man
yes
You could have any of the 3 two tone paint jobs....
white cab roof on a colored truck
white cab roof and white from the belt line on down with colored inbetween
or, as seen on that bed, white/color/white/color.
Old 11-21-2005, 12:12 AM   #5
Striker169
Car O'Holic
Striker169's Avatar
what about not white in the middle of the trim but a lighter green? was that an option or just white?
Old 11-21-2005, 12:18 AM   #6
Longhorn Man
I thought that was bad lighting.
Any color could be had, but GM would recomend certian ones.
I have seen one that was like the white/color/white color...but the white was yellow, and the color was red.
it looked like crap.
Those colors may well be original, but 99% of the ppl who would see it would say you are wrong.
Old 11-21-2005, 01:11 AM   #7
Striker169
Car O'Holic
Striker169's Avatar
oh I know that its not origonal inside the tail light housing its yellow, but I really like the combination, its a real real light green like you said almost white, and then the dark green. I dono if I want to go white cab and white in the middle or white cab with that light green. BUT I was just wondering if the trim and whatnot was year correct. Also what was the difference in the CST, Custom, and Cheyenne Packages?
Old 11-21-2005, 09:14 AM   #8
I have the`71 ordering book,so it could be different.I just noticed recently that the Deluxe two-tone(your bed) was only offered with white as an accent color.The Conventional two-tone(accent color under belt-line and on top)was offered with certain other combinations.That seems to be the most diversified way to go on colors.The Standard two-tone(accent color top)was offered with other accents,too.Mostly,it was combinations of Medium Olive with Grapefruit or Dark Olive.
Old 11-21-2005, 10:39 AM   #9
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
CST for '69. Cheyenne came later. I was led to believe there wasn't a 2-tone option for '69. Help on this one?
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 11-21-2005, 01:59 PM   #10
[QUOTE=I was led to believe there wasn't a 2-tone option for '69. Help on this one?[/QUOTE]
Do you mean the Deluxe two-tone with color on bottom/white middle/color upper/white top?You may be right.The other two were always available since`67.(top only & top/below beltline)
Old 11-21-2005, 04:36 PM   #11
Longhorn Man
Here is longhorn Jeff's all original 69 longhorn CST Camper Special/20. (the green one) The gold one is a 70 (original paint also) that belongs to a member whom has been gone for a couple years..anyone remember PigPen? He sold this truck a few years ago after painting it, but this pic shows the original paint.
Old 11-21-2005, 10:00 PM   #12
mblackburnjr
collector of vintage rust
mblackburnjr's Avatar
Was the painted on pinstripe ever used as a color divider?.....just curious.
mblackburnjr is offline   Reply With Quote
Old 11-21-2005, 11:09 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My 1969 Truck Data Book shows two two-tone combinations.
1. Two Tone: Solid color on body, with a white cab roof with "rear belt moulding".
2. Special Two Tone: Roof and that portion beneath the lower body side moulding in white, with the remainder being a different color.
Body paint stripe, option code RPO D89: Painted side stripes are available optionally for Series 10-30. White paint is used in all cases except with White, Yellow and Silver exteriors, where Black paint is used. (This would be in lieu of RPO B85, Custom Upper Side Mouldings).
Member Nr. 2770
Old 11-21-2005, 11:32 PM   #14
Longhorn Man
Chevloray, I can attest that longhornJeff's green and white truck is not only original paint, but also an early 69 model. I have looked over his truck many times.
Old 11-21-2005, 11:56 PM   #15
Striker169
Car O'Holic
Striker169's Avatar
gosh thats a long list of options
Old 11-22-2005, 06:36 AM   #16
Longhorn Man
it's an awsome truck.
Old 11-22-2005, 08:24 AM   #17
Is the type of two-tone indicated with a specific RPO#?I`ve never paid this any mind till now.
Old 11-22-2005, 09:40 AM   #18
1969 C/K CST
A.K.A- Crummy
Thanks for the info. I knew about the usual white top, but wasn't sure of the full 2-tone.
Old 11-22-2005, 12:25 PM   #19
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Special-K: To answer your question, the paint code denoted whether or not it was a Conventional Two-Tone, or Special Two-Tone. For example, a black truck, like mine, has a paint code of 500. It's all one color. If it was a conventional two-tone, it would have been paint code 530. In that case, it would have had a white top and there would have been a piece of trim at the back of the cab to denote the color break.
It had been a Special Two-Tone, it would have had a paint code of 586. This would have denoted the white top, AND the white portion beneath the lower body side trim.....as on CST's and Custom Comfort and Appearance options. The part of the body above the lower trim and the cab, would have been black. No two-tones were available on white bodies, Cowl or Bus chassis'.
Olive Green, special 2-tone: 538.
BTW, there are some colors on the chart that I don't recall seeing. How about y'all???
These are 1969 colors for series 10-60:
Yellow (metallic) code 520; Dark Yellow code 519. I know I remember seeing a light yellow, which must have been code 520, but I didn't know it was metallic. The dark yellow sure looks like my school bus.
Member Nr. 2770
Old 11-22-2005, 11:33 PM   #20
Thanks,now that you pointed it out,I do remember the whole variation in code for a given color according to the paint scheme.
The factory refered to metallics as poly,I know that.I don`t know of a metallic yellow ever being offered,either.
