![]() Join Date: Apr 2000
73-87 front end
im going to run 73-87 chevy front spindles on my 69 chevy do i have to change the upper and lower control arms to do this or will the 69's work?
Brandon 67 chevy CST 68 chevy stepside US ARMY truck 69 chevy longbed green and white Custom10 05 Honda Rancher AT with 26 inch ITP 589's 2008 Chevy crewcab vortec max 4X4 pickup 1969 Chevrolet layin frame Project Fools Gold http://67-72chevytrucks.com/vboard/s...d.php?t=257593 |
MY EX DRIVES A BROOM
no you don't just the ball joints and outer tie rod ends with adapters to mount to the 69 inner tie rod ends or better yet go to the yard and get the entire steering linkage from a 71-87
They say nobody's perfect. I'm a nobody, so I must be perfect. Building Nemo -1968 C10 Long Bed FRED -1947 KB-2 International |
You can use 73-87 Suspension items on 67-72 Trucks but you must do as following:
Must use: Upper and Lower Control Arms 73-87 Shafts must use from 73-87 Spindles from 73-87 Ball joints must match Spindles Must use outter tie rod from 73-87 Must use inner tie rod from 67-72 I'm in the process of Building a different front end for my 72 GMC C-1500. I'm using the above items on a 73-87 crossmember with all new Moog parts, 3'' lift Springs from FabTech, all new Disc brake items, and braided brake lines. I have part #'s from the items I'm using if you want them. |
No, you dont need to swap the a arms. if you use the balljoints & all steering linkage from the later truck, it all fits. you may find that you need to grind the steering stops when using the 67-70 lower a arms ,with the 73 up spindles tho. I used 71-72 lower arms ,with '75 spindles & didnt have any problems . best of luck....
http://community.webshots.com/user/hotrodhorn |
My bad!
![]() Join Date: Jun 2002
I could be wrong but I believe you will need new flexible brakeline hoses...
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
Yes, the brake hoses do need to be replaced! I used all the pcs from a '75 c-10(lines , hoses,calipers,master,prop valve,wheel cyls ect) . For a manual disc setup,she stops good
