Old 09-21-2005, 11:28 PM   #1
Whynot
Chevy rack & pinion
You Guys that have changed out your 67-72 steering over from the stock GM box to a power rack & pinion set up. How do you like it ? Seems like you should notice a lot diffrence in the steering. Can you ? I'm guessing most of you are using the unit from a early model 80s Ford. Looking at a Ford in the junk yard seems like all you have to do to mount it,is to weld on a couple taps for the rack to bolt up to. Not sure about the steering column shaft. What you do, ad a few u-joints and shaft between the column and the rack ? Should not be that hard to fab up. Any Info will be grateful. Also if you done this an have pictures of the rack and steering hookup. Let me know,Ill send you email address for a few attachments. THANKS !!!!!!!!
Whynot is offline   Reply With Quote
