Best way to clean glass w/o scratching?
I have a used rear glass that has some hard water stains, what is the preferred method of cleaning that off with out scratching the glass?
Thanks!
78 C10 LWB Super Cheyenne |
Re: Best way to clean glass w/o scratching?
BON AMI scouring powder good for glass
Rolled on Paint Club
![]() Join Date: Jan 2006
![]() Work up a good wet paste and polish it gently with a soft rag then rinse with lots of water. Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
Questionable
There is this stuff at the store called Spot-X, think it's made by the same people who make Rain-X. You will absolutely not believe how well this stuff works. It is worth the $12-18 you will pay for the bottle and you won't be able to find enough uses for it. I found out about this stuff living in central FL and having glass shower doors in all the bathrooms in the house. The scaley water spots wiped off when nothing else would work. Then I found it works on cars and the outside of the house's windows (from sprinklers and crap), even removed the rust stains from the wall (water was heavy in iron)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-11-2006 at 10:05 AM. |
thanks for the tips... I'll see if I can find that spot-x around here if not I'll give the bon-ami a try.
thanks again.
good idea try the $18 stuff B-4 trying the $1.49 stuff
Steel wool, grade 0000. Wont scratch glass and in fact the package says can be used to polish glass.
Bill |
#8 | |
so easy a caveman can do it...
![]() Join Date: May 2006
