Old 12-17-2012, 02:15 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
Good Power train Combo??
With the help of the great forum members here I have been able to identify the parts and pieces that the drive train for the 1956 3100 I have been working on consist of. I was wondering what you guys think of for its performance and efficiency outlook.
Engine - CID (1967 impala 275HP Factory rating /600 Edlebrock cab / Edlebrock torker intake / HEI / Ram heads exaust / camel back heads
Transmission - TH350C (79-84 Chevy)
Rear end - 3.08 GR 10 bolt (71 Chevelle)
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 12-17-2012, 01:02 PM   #2
lts70
1970 Daily Driver
lts70's Avatar
Re: Good Power train Combo??
The tires will be 235 70 R15. I believe that is a 27.9" tall tire
The transmition gears are 2.52, 1.52, 1
I think at 65mph the truck would be spinning 2491RPM's
I used this calculator
http://www.csgnetwork.com/multirpmcalc.html
What do you guys think?
Old 02-16-2013, 01:25 PM   #3
lts70
1970 Daily Driver
lts70's Avatar
That's decent right?
Old 02-16-2013, 01:34 PM   #4
Longhorn 70
Longhorn 70's Avatar
It's great but uses a bit more fuel than modern setups due to no overdrive. It's a bit more work and money but 700R4s or 200's have overdrive and a bit deeper first gear. Mine moved me from12 MPG to 15 MPG. I know it's a small change number wise but it is an increase of 25%. The engine also works less....?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
