Old 12-12-2005, 03:25 PM   #1
Jim85IROC
Jim85IROC's Avatar
what gauges can I use in my truck?
I've got an 87 GMC 3500 with a tbi 454. I have no tach. I want one. I read the gauge swap page on 73-87.com, but it's pretty vague about what will work in my truck. Will any tach-equipped cluster that has a VSS work?
1987 GMC Sierra Classic 3500
454
TH400
My Sounddomain Page
Jim85IROC is offline   Reply With Quote
Old 12-13-2005, 01:05 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Re: what gauges can I use in my truck?
VSS? Not sure what you mean by that.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 12-13-2005, 10:36 AM   #3
Jim85IROC
Jim85IROC's Avatar
Vehicle Speed Sensor. It is necessary for the tbi computer to function properly, and why I think that the "regular" gauges won't work. On the 73-87 article, he mentions that you can use the older gauges if you swap your CCC (computer controlled carb) for a normal carb... hence eliminating the need for the VSS. But... the opposite should be true... I should be able to use the gauges from any truck with the CCC on my truck because it'll have the VSS. I just want to confirm this before I drop $100+ on a set of gauges.
454
TH400
My Sounddomain Page
Old 12-13-2005, 12:39 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Jim85IROC, you need to get one that has the VSS on the back to work with yours. As long as the cruise used the VSS, you should be ok. Post what you find and we can help you out on your selection choices.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-13-2005, 04:54 PM   #5
Jim85IROC
Jim85IROC's Avatar
454
TH400
My Sounddomain Page
Old 12-13-2005, 08:09 PM   #6
beaterC10
Couldn't he just swap his VSS speedo into the a non-VSS cluster? I thought the VSS was just a sender off the back of the speedo. If he used 81 -87 the gauges would still match.
beaterC10 is offline   Reply With Quote
Old 12-14-2005, 08:27 AM   #7
greg0380
FWIW, I just replaced the old mechanical speedo with an Autogage Procomp electric speedometer. My truck is an 85 but I swapped in FI from an 87 (7747 computer). If your old speedo is cable driven, you can replace it with another new cable driven, but you will need an inline VSS that will send pulses to your ECM and all will work again. I was using one for a while with my old cable driven speedometer. JagsThatRUn sells them (and other companies). It worked fine.
THe Autogage electric speedo comes with a buffered VSS output that was supposed to send the correct pulses, but it was not the correct frequency so I had to used a converter.
1985 GMC Sierra 1500, 1/2 ton, 2WD, LWB, TBI 305
5 speed, 3.42 rear
2007 GMC Sierra 1500, xtended cab, 4X4, flexfuel 5.3L
1999 BMW 528i
greg0380 is offline   Reply With Quote
