Old 12-19-2005, 05:33 AM   #1
l1n1b1
67 Shortstep
Brake Job on My '67 Shortstep
I plan on doing a complete brake job on my 67 Shortstep. I have the original 6 lug drum setup front & rear. I just recently aquired the truck & was told that it had been sitting up a while. I'm assuming that it currently has DOT 3 fluid in the system now, but it looks pretty funky. If I replace all 4 wheel cylinders, blow all the brake lines clear, & empty the master cylinder, will it hurt anything to go back with silicone brake fluid? Are there any advantages to using silicone brake fluid vs. DOT 3 fluid? Or do I need to just stick with the DOT 3?
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Adapt, Improvise, Overcome
l1n1b1 is offline   Reply With Quote
Old 12-19-2005, 05:55 AM   #2
andyman1
Re: Brake Job on My '67 Shortstep
silicone brake fluid is desinged for todays vehicles higher temp. braking systems. it WILL work in older applications, for the price, i still use dot3. from Andyman1-cert. ASE brake tech.
andyman1 is offline   Reply With Quote
Old 12-19-2005, 06:00 AM   #3
l1n1b1
67 Shortstep
Thanks andyman....This truck is for my son to drive back & forth to school, so I was just thinking that the silicone fluid would make the brake system 'er'...Just didnt know if its too much sugar for a dime...
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 12-19-2005, 08:06 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
also just draining the MC and blowing out the lines will NOT get all the old fluid and "crud" out. it will mix with the silicone & create havoc.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 12-19-2005, 11:49 AM   #5
l1n1b1
67 Shortstep
So the best thing overall to do would be empty the system as much as possible & go back with DOT3, right?
67 SWB Step
69 LWB CST
71 LWB
94 SWB Step
05 1500 Dodge P/U
Old 12-19-2005, 12:21 PM   #6
FormerMember
That is what I would do.
No real increase to be had from anything else.
I could see if you swapped in C5 suspension and brakes.
FormerMember is offline   Reply With Quote
Old 12-19-2005, 01:32 PM   #7
krue
Designated A-hole!
krue's Avatar
Go with the tried and true.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-20-2005, 07:52 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The advantage of silicone is that it's not hydroscopic. That is, it does not absorb moisture from the atmosphere. That makes it ideal for infrequently driven vehicles too.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
