1992 Chevy Instrument Cluster
I was wondering if anyone has ever replaced thier standard cluster with one that has a tach. Is it already wired? Can I just replace it and plug it in or do I need to get a different harness? Thanks to anyone that can help!
Scott ![]() |
Re: 1992 Chevy Instrument Cluster
let me know on this too i have found many clusters but dont know if they will go right in i have found em in dallas and houston for 50 bucks with a tach my truck has no tach and i hate it....Steve
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Try this link:
http://www.fullsizechevy.com/fscu/88-93tach.shtml
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
ok so that explains 88-93 how bout 94 my truck is a 94 but no tach just a simple plug and play right?,......yeah in my dreams
I am not completely verson on the 88-99s, but I believe the wiring is there.
Yea, that's what I was wondering. 92-94 is the same. Can I just plug in the tach version and go?
Scott |
#7 | |
#8 | |
Also keep in mind, the instrument panels is not the same for a V6 as it is for a V8, if it has a tachometer. The tach will not read correctly if replacement instrument panel was from a vehicle with a different number of cylinders. If you are capable of soldering good enough to change parts on a circuit board you can convert them, if they don't match your engine. Last edited by ChevyTech; 01-06-2006 at 07:54 PM. |
