Old 02-09-2007, 01:50 AM   #1
skokie
skokie's Avatar
Zinc Coating on new fender
I bought a new fender for my 68 and it has a zinc coating. I was thinking about taking it to a body shop and have it sprayed with something to seal it. So I call around to 2 shops and tell them what I have and I get 2 different answers.
1st answer: Its zinc coated? No need to do anything with that. Just put it on there it wont rust.
2nd answer: Its zinc coated. Well you can brink it down and we can spray it with a primer/sealer (cant remember exactly word for word) and clear coat it.
So heres the question. Do I need to go with the 2nd answer or the 1st?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 02-09-2007, 02:27 AM   #2
CHAPS7931
CHAPS7931's Avatar
Re: Zinc Coating on new fender
http://www.azom.com/details.asp?ArticleID=521
http://www.azom.com/details.asp?ArticleID=1075
try this website because i think its the first answer, tells you all the diferent types of zinc coats
CHAPS7931 is offline   Reply With Quote
Old 02-09-2007, 03:07 AM   #3
FarmTruk
In Memoriam...
FarmTruk's Avatar
Paint it...have you ever seen a rusty galvanized fence metal roof, or bolt head. I have.
The zinc coating breaks down over time, and the paint will protect the coating.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-09-2007, 04:27 AM   #4
Morgsie
I thought galvanized and zinc plating are two different things.
Morgsie is offline   Reply With Quote
Old 02-09-2007, 10:17 AM   #5
sleepyboy
'69 Step
http://www.metalplate.com/galvanizing/TIS4.HTM
galvanizing is a zinc coating
sleepyboy is offline   Reply With Quote
Old 02-09-2007, 11:06 AM   #6
jay-dawg
chevelito
jay-dawg's Avatar
the color fades, especially under the sun. I know because mine has done that. It will rust too. Get it sprayed.
Jay
New deadline...when my son can drive.
Aloha from Honolulu, HI
jay-dawg is offline   Reply With Quote
Old 02-09-2007, 11:34 AM   #7
skokie
skokie's Avatar
Thanks for the info. Its headed to the body shop for a coat of sealant. Any thoughts on what would be good to paint it with? The truck will not be painted until next year. A primer with clear maybe?
68 build thread
Old 02-09-2007, 07:18 PM   #8
Schralper
Schralper's Avatar
They are!
Electroplating, or plating, uses electricity. Anode and cathode. Like brake boosters, nuts and bolts, some oil pans, etc. The yellow, blue, etc., chromates add the color and some corrosion resistance.
Galvanizing is molten zinc in which the part is run thru and let cool. It's used w/ corrosion in mind.
Schralper is offline   Reply With Quote
