Pic Needed: Roch 2bbl Carb Linkage
I'm trying to hookup the linkage on a rochester 2bbl carb...this carb is replacing the factory q-jet...the manifold has been swapped to the 2bbl intake. I just need a pic of the throttle bracket etc for the 2bbl. Thanks.
Re: Pic Needed: Roch 2bbl Carb Linkage
btt
i may have one ill see what i can do
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Here is my monojet, but just like a 2GC. It is all manual from 1967. If you were to set up this carb for a cable accelerator, just attach a ball-stud in the hole that has the accel-linkage, and you will then need a bracket in the back of the intake that mounts to the intake, or the coil bracket. They are available universal from NAPA, or aftermarket.
Automatic transmission will need a kickdown. That is not shown in my picture. ![]()
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
Ah, that's my problem (thanks). I got this intake and carb from a '69 C10. It's now (temporarily, while I'm building a new engine) on my '77 C10 (cable throttle). I bought a 'universal' bracket that uses one of the carb studs, but it interferes with the linkage on the carb.
Any links to the mainfold bracket that I need? |
Not trying to hijack the thread but what is the spring connected to near the coil?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
My intake has a bracket on the rear that the spring attaches to (near where the coil would be...if mine wasn't HEI).
Here is a better picture of the spring bracket. It appears that under the grime, it attatches to the intake at the coil mounting bracket.
