Old 01-30-2006, 01:13 PM   #1
JRB
JRB's Avatar
Opinions on what kind of Shocks (Lowered)
I just lowered the front of my 69 Short Step. I was wondering what kinds of shocks that other people have put on their trucks after lowering them. Give some feedback about their perfomance and how they effected the ride of the truck.
Thanks,
JRB
JRB is offline   Reply With Quote
Old 01-30-2006, 01:40 PM   #2
NPilot1975
NPilot1975's Avatar
Re: Opinions on what kind of Shocks (Lowered)
I have a 4/6 drop on my truck from ECE. They use KYB shocks as does Air Ride Tech. I have about 5500 miles on the truck and think it rides great.
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 01-30-2006, 02:18 PM   #3
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I put Doetsch Tech shocks on mine front and rear. Also bought CPP's relocator kit that helps do away with the severe angle you start getting when these trucks are dropped down out back. Everything went together pretty easily. I like the DT shocks as they are a bit stiffer than the stockers but not too stiff. If you plan on lowering 4" or more out back you need the relocators also. The lower mounts just bolt right up. The upper mounts you need to drill out the stock mounts as they are riveted to the frame. I used an air chisel to pop the heads of the rivets off and then just tapped the rest out with a punch & hammer. Piece of cake.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-30-2006, 03:40 PM   #4
JRB
JRB's Avatar
Im only going down 2 inches will I still need the shock relocator?
JRB
Old 01-30-2006, 03:44 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
JRB
No.
Btw, later today I'll post the model # for the KYB Gas-adjust shocks I'm using. They're awesome.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-30-2006, 04:53 PM   #6
72MARIO
72MARIO's Avatar
Doetsch Tech shocks are pretty good thats what on my 67. Dont have any problems with them.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-30-2006, 08:40 PM   #7
Z28Owner
Z28Owner's Avatar
I used Summit 2 inch drop shocks, reboxed Toxic shocks, only got about 1500 miles on them, seem to ride fine.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 01-31-2006, 06:03 PM   #8
Brad
Brad's Avatar
I use KYB Gas-a-just shocks model #KG5409. These are the best shocks ever! I use them on the front and the rear. I have a 5" drop and use the ECE shock mount relocators also.
Old 01-31-2006, 06:13 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Hi Mario.. Can you post a pic or two of your maple wood bed and let me know where you got it from. I know the maple is a lot lighter than oak and think that will work better on my truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-31-2006, 06:22 PM   #10
Frizzle Fry
Frizzle Fry's Avatar
I've got KYB Gas-a-Just on all four corners of my dropped BB Burb. They do make a big difference, especially in the rear.
No relocater for me with 2.5" blocks in the back. You only need them with rear drop springs, not with blocks. Blocks retain stock geometry.
Frizzle Fry is offline   Reply With Quote
Old 01-31-2006, 07:28 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They must have changed recently. I bought Summit brand drop shocks a few years ago, and they are Doetsch Tech stamped right into the bodies.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-02-2006, 06:16 PM   #12
JRB
JRB's Avatar
First I would like to thank everyone for your help and replies. I was wondering if 65dollars per corner for a set of KRB shocks is a good price?
Thanks,
JRB
Old 02-03-2006, 07:08 AM   #13
Tx Firefighter
That's pretty high.
ECE sells a nice set of 4 KYB's for something around 130 dollars.
Old 02-12-2006, 03:58 PM   #14
lux hauler
Psycho-billy Member
lux hauler's Avatar
Thanks,
JRB
Summit has KYB Gas-A-Just for $30 each.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
