Old 03-07-2006, 10:34 PM   #1
iamthor
iamthor's Avatar
UPDATE! - Rear Clamshell Lift Supports
So I finished this a few weeks ago but had no time to get out and shot some photos. I ended up having to go with a stronger shock than I thought I would previously (http://67-72chevytrucks.com/vboard/s....php?t=184824). I did not take into consideration that the hinge on the door is not a simple "door hinge" design. When closing the top door the struts completely compress then reopen a few inches. This actually forces the door to stay closed. I took all the measurements but can't find them right now. I will post them as soon as I can. I will also submit all the info to Jolly at www.6066gmcguy.org so he can make a page for it if he likes. I will probably end up riveting the brackets to the truck for a cleaner finish then the temp screws that are there now. Check it out. Let me know what you think.
Rollin in my 64....GMC Suburban
iamthor is offline   Reply With Quote
Old 03-07-2006, 10:35 PM   #2
iamthor
iamthor's Avatar
Re: UPDATE! - Rear Clamshell Lift Supports
...and more.
Old 03-08-2006, 09:57 AM   #3
61burb
61burb's Avatar
hey that looks like it works good. i would love to get the mesurments and strut info from you when you get a chance. matt
61 GMC Suburban
63 GMC 4X4 Suburban
66 Chevy C-10 LWB Fleetside
61burb is offline   Reply With Quote
Old 03-09-2006, 03:00 PM   #4
Frizzle Fry
Frizzle Fry's Avatar
Looks great! What did the struts come from?
Frizzle Fry is offline   Reply With Quote
Old 03-09-2006, 03:51 PM   #5
iamthor
iamthor's Avatar
The struts are from a marine supply company. They were the only company I could find that provided extended and compressed lengths plus different Lbs. ratings. I went with two 30lbs's but they proved too weak. So I ordered two 60lbs's and they did the job. I also got 4 pairs of different brackets to see what would work best. Here the link: http://www.go2marine.com/frameset.js...review%3Dfalse part# 90641. I will post all the final part numbers along with the measurements as soon as I get back to the burb to measure it.
