Professional Grade
Vent Window Seals?
Hey guys!
my 77's vent windows leak like crazy, and are driving me nuts. Is there anything I can do to make them seal properly again? I was thinking about just siliconing them shut, since I never use them anyways...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Insert Witty Text Here
Re: Vent Window Seals?
That is the easiest thing to do if you don't ever plan to use them again. The PO on mine stuck some foam, adhesive backed weather stripping on the sealing surfaces. It might help. I have also heard that putting a dime or other thin coin under the latch will make it latch tighter.
Slonaker Last edited by Slonaker; 02-21-2006 at 04:01 PM. |
What Hump?
the dime or the thin coin probably would work better than the paper towel I have folded up under the latch, lol.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
On my last truck i had a little piece of steel bar in there that helped out alot. And the silicone sealed the deal.... haha
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
On a budget like Fred Sanford
I did the "never use these anyway" silicone treatment. Seems to be working so far!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
