Old 03-08-2006, 01:48 AM   #1
four-eyed stang
81 LWB uneven in the back
I am going to buy an 81 LWB this weekend from a buddy of mine and noticed that the truck is uneven in height at the back of the truck. Both tires are aired up. What could be causing this, weakened leaf spring?
four-eyed stang is offline   Reply With Quote
Old 03-08-2006, 02:02 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: 81 LWB uneven in the back
Probally a broken leaf. My GMC used to sit about 2" lower on the left than the right becuase of that
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-08-2006, 02:06 AM   #3
four-eyed stang
That was what I figured. I am going to put new overload springs on it as it is going to be used as a tow vehicle. I guy at my work told me that alot of old Chevy 1/2 ton farm trucks had cracked frames because they use to but full hay bails in the back and would crack them bouncing down the road. I figured if the frame was busted it would be alot worse than it was.
Old 03-08-2006, 06:49 AM   #4
bluex
bluex's Avatar
If its just a slight difference it could be from the gas tank. All the years of hauling around 20 gals of gas on one side makes that side sit a little lower.
bluex is offline   Reply With Quote
Old 03-08-2006, 12:34 PM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Could also be that the bed supports are rusted away and letting it drop down on one side.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
